Hello everyone,
I am a bit confused on the terminology surrounding recessed lights. I fully understand the IC and non-IC designations. My confusion comes when you begin to talk about the housing and trims. To me, the trim should mean nothing more than just a cosmetic trim ring and the housing should comtain everything else..is that correct? I did a search for 'recessed' on here and didnt come up with an answer to my question. I did however see that I should look at the Juno brand. So I am linking to a product at Lowes and will try to go by monday after work to check it out, but is this all i need (and some beauty trim ring)??
http://www.lowes.com/lowes/lkn?action=productDetail&productId=105146-38269-IC22&lpage=none
Juno Lighting
1 Light IC New Construction Housing Recessed Lighting
FYI: I am doing a new construction.
Juno Lighting
