Recessed Lighting For Ceiling Tiles?'s - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-03-2007, 08:39 AM   #1
Hello
We've decided onusing ceiling tiles (a.k.a Armstrong) in our garage but with a grid system that attaches directly to the joists instead of suspended. I've never done recessed lighting and I'm confused to which or what to look for and get. I've seen new construction and remodel. Small to large housing and some that seems to just lay on top to those that connect to the joists. It seems like the remodel ones are the best so I can center in the tile but what about wiring? I've done several ceiling fans and lights mounted to a 4x4 box. Is one style better than others? Thanks
Kenny J
Stargazer is offline   Reply With Quote
Old 09-03-2007, 12:09 PM   #2
Rewards Points: 5,336
You don't want the weight of the can on ceiling tile, so put in the new construction units that attach to the joists. If you have 2x8 joists or larger, you can use the deeper cans which are made for 2x8's and larger. Generally the bigger the can, the larger the wattage bulb that can go in. The can and the trim choice will dictate bulb wattage. Do you want the lights dimmable? Do you want the new florescent lights that are only a fraction of the wattage of incandescent and produce alot less heat?
All these issues can effect can size.
Ron
Old 09-03-2007, 07:48 PM   #3
I really haven't laid the lighting out but the room is a large "L", 14x14 area for the seating and the other for a pool table. I'm guessing (4) for the TV area and (4 or 6) for the larger section. I like the smaller "eyeball" that's about 5"-6" and can rotate. I'd like to break it up on seperate switches and yes able to dim.
This is the tpye of light I'm looking at:
http://www.lowes.com/lowes/lkn?actio...78P&lpage=none
So you're saying to get a housing like this:
I guess that's what I'm trying to figure out. There are several types of housings let alone lights. The joist are 2x8's with insulation stapled to the sides. Nothing above. I'm just want to get the right match (housing/light) or new construction or remodel. Thanks for your help.
Kenny J
Old 09-03-2007, 10:38 PM   #4
Inside each housing can is a list of trims you can use with that housing and the wattage limit to each of the combinations.
Both the links were for the eyeball trims. If you have insulation close by, that will also reduce the wattage you can use. The "IC"(Insulation Contact) housings have more wattage restrictions then say non IC because the heat can be dissipated easier.
Just look inside the housings for the list of trims you can use.
If you bank together dimmers, just remember, there is a reduction in wattages that can go on each dimmer. One dimmer, 600 watts. Two dimmers side by side, 500 watts each. Three dimmers, only 400 watts each.
Ron
Old 09-04-2007, 12:15 AM   #5
Thanks once more for chipping in. If that's the case would the low volatage (halogen) be a better choice in terms of less watts combined with dimmers? How does Halogen compare with Incandescent in terms of lighting, energy and long term? Also most of the bulb recomendations are for 75W. You can use less say 60W or the bulb/wattage specific?
Kenny J
Old 09-04-2007, 07:58 AM   #6
You mention using between 8-10 lights. Ten lights at 75 watts is 750 watts. Separated on two dimmers is 375 watts. That's well below the 500 watt max for side by side dimmers.
You can use low voltage lights, just realize the initial cost of the lights will be 2-3 times the cost of the line voltage material. Useage costs will be less,especially if the rooms are used alot.
Low voltage bulbs last much longer then incandescent bulbs. I put 12 low voltage cans in my brother's kitchen when we remodeled it 8 years ago. He hasn't had to replace one yet. The 35 watt flood lights give a clean bright white light. His kitchen has cathedral ceilings. In a basement setting you may need more lights due to a lower ceiling then you would with the larger incandescent cans.
Ron
Old 09-04-2007, 09:42 AM   #7
Question
Since you are on this subject I will not start a new one, I am planning to remodel my basement and would like to put low wattage Recessed Lights in the Ceiling, my rooms are 26' X 11' and my other room is 33' X 12' and my ceilings are 7'. How many recessed lights do I need in each room?
The 26' X 11' is a Bedroom and also a Office area.
The 33' X 12' is a TV room with a dinning area.
What I would like is the lighting that would not use allot of wattage to save on the electric bill. There is no insulation in the ceiling of my basement. I plan to put paster-board up on the ceiling and walls.
What I would like to say is I am looking to get the most light with the less amount of wattage.
Please gave me your advise in which way to go.
Rifeman is offline   Reply With Quote
recessed lighting wiring to 3way switch DIY4EVER Electrical 1 07-12-2007 01:35 PM
recessed lighting in basement DIY4EVER Electrical 6 06-29-2007 02:52 PM
Recessed lighting in drop ceiling DIY4EVER Electrical 9 06-04-2007 04:46 AM
Recessed lighting wiring? Kriv Electrical 2 10-17-2006 02:21 PM
recessed lighting automation cesar333 Electrical 3 12-28-2005 08:54 AM
