Recessed lighting in basement - thoughts on layout
I'm putting up recessed lighting in my basement and would appreciate some thoughts on the lighting layout I'm looking at. The room is 21 x 12 feet and will be used as a bedroom, or at least half will have a bed and the other half a sofa and chair for general reading/relaxing. There are two small windows at one end of the room. I'm looking at putting up 6" compact recessed cans with 75w dimmable R30 floods, 4 rows of 3 on 2 circuits, for each half of the room, so 12 lights in total. Will have both circuits on dimmers so want to make sure I've got enough light to start with... The ceiling height is 6'7. Would appreciate some comments on whether this is enough light given the room size and relatively low ceiling height. Thanks! David
You really need to post a drawing of the floor plan.
__________________ To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
As I am figuring it, 12 floods are going to put out roughly around 1,320 degrees all together. Talk about baking a room.
8 cans maybe even 6 will be more then sufficient for that area. Especially with such a low ceiling.
You mention that someone will be sleeping in the room,by code the room is required to have an exit in case of fire be it a door or egress window.
The Following User Says Thank You to sublime2 For This Useful Post:
Go with LED lighting. Less heat, and can use one circuit to power.
It is not about the upfront costs, it is the long term, which you will be glad that you did go with LED vs. Incandescent or CFL PAR's. Spend the money for the LED fixtures instead of cheaping.
you can use 3w LED standard A base bulbs inside can lights, use the can light adjustment to bring the bulb down thereby getting a better light dispersion. The 3w or even the 8w ones I'm talking about will run about $5 to $12 dollars, but think about it like this 12 3w bulbs = 36w. 12 PAR30 bulbs = 360w. That is a 100% saving of electricity usage. Also the LED bulbs are instant on, as opposed to CFLs, will not hum when dimmed as Incandescent bulbs do (unless rough service bulbs), and have a 50,000 hour life as opposed to around 5000 fro incandescent or 10,000 for CFL.
