Old 07-30-2014, 01:40 AM   #1
Share |
Recessed Lighting
I am remodeling my bathroom, and want to install some recessed lighting. I want something that is not going to produce heat above the unit. Will LED work? Will it need to be made specially for bathrooms (Moisture)
Any opinions welcome.
cincinnati guy is offline   Reply With Quote
Old 07-30-2014, 05:10 AM   #2
Recessed Lighting
I installed led recessed lighting and it is rated for insulation contact. It stays pretty cool.
LED lighting is great but recessed lighting not so much, especially in a bathroom. They are hard to airseal and the bathroom is NOT a place you want to have air leaks into the attic.
I would look at alternatives to recessed lighting if you can still change your mind. There are many attractive, sleek options that don't carry the risks/problems of recessed.
strategery is offline   Reply With Quote
Old 07-31-2014, 06:35 AM   #3
Recessed Lighting
What other sleek/attractive options are you referring to?
Old 07-31-2014, 08:37 PM   #4
Recessed Lighting
Flushmounts.
If the energy penalty of recessed lights doesn't matter, then go ahead and install those. I'm just not a fan of recessed lights.
Old 07-31-2014, 09:18 PM   #5
JOATMON
ddawg16's Avatar
Recessed Lighting
I have 6" recessed cans in numerous places....with LED bulbs in them. No issues....
They also make dedicated LED recessed cans...
go for it.
"The dream is free but the hustle is sold separately."
Old 08-01-2014, 10:50 AM   #6
Pro
Recessed Lighting
LED recessed lights are great - either dedicated LED or the standard unit with LED retrofit finisht. New ones are very airtight, especially with a shower/damp location finish.
They still get warm - nowhere nearly as hot as incandescent or halogen, and not so much from the LED itself but from the driver/transformer, but still hot enough to be uncomfortable to handle with bare hands.
In California, the law basically requires a dedicated LED fixture (rather than LED retrofit in screw-in base). Probably not the case in Ohio.
Robert Cram
Robert Cram Construction
CarpenterSFO is offline   Reply With Quote
Old 08-15-2014, 08:49 PM   #7
Recessed Lighting
ditto on the LED's!
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Old 08-16-2014, 06:19 AM   #8
Exterior Construction
Windows on Wash's Avatar
Recessed Lighting
Get an airtight can as well. Problem solved.
Help with Replacing Recessed Lighting from the 80's scubakathy84 Electrical 2 11-03-2012 04:57 PM
Kitchen fluorescent to LED recessed lighting changeout speedytahiti Electrical 1 01-05-2012 07:04 PM
New recessed lighting: Line Voltage vs. low voltage hyunelan2 Electrical 0 10-12-2009 12:25 PM
Recessed Lighting - Quality Question. 811Gibbon Electrical 8 01-24-2009 09:47 PM
Recessed Lighting under hot/cold supplies?? KC10KEVIN Electrical 1 05-08-2008 10:21 PM
Copyright © 2003-2014 Escalate Media. All Rights Reserved.
