ReCaulking Windows & Trim - Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-30-2014, 08:18 PM   #16
Rewards Points: 135
I can't find the Superior Sealants Bolt product and do you mean DAP DynaFlex 230 or Dap Alex Ultra 230?
If I primer and paint over the Big Stretch will it still attract more dust than usual caulk that dries completely?
MsKitty32 is offline   Reply With Quote
Old 01-30-2014, 09:30 PM   #17
Painting Contractor
Rewards Points: 167
The main area of concern with the Big Stretch attracting more dust would be across the top of the baseboard, vertical runs would be fine. It's just a personal quirk with me that I like the caulking to dry hard, but I know some contractors that use Big Stretch exclusively. I tend to only use it on crown molding because it is typically a problem area. The Bolt caulk should be available at your local independent paint store. Lowes carries White Lightning which is a slightly lower grade than Bolt, but has lots of adhesive, and after re-thinking this, I would probably go with that instead of the 230. Also you will want to have some 80 or 100 grit sandpaper to smooth any areas where your cuts are a little rough, before you caulk.
VAProPainter is offline   Reply With Quote
The Following User Says Thank You to VAProPainter For This Useful Post:
MsKitty32 (01-31-2014)
Interior Trim on "All Ultrex" Windows mnspartan Windows and Doors 8 12-21-2014 09:43 PM
Re: old buildings RWolff Building & Construction 157 01-19-2014 12:35 AM
Adding vinyl trim to existing windows rismith1 Windows and Doors 1 12-11-2011 03:47 PM
White vinyl windows with wood trim... crazy? rnjsbungalow Interior Decorating 5 04-16-2009 05:53 AM
windows trim with board and batten sidings zdenek Remodeling 2 11-23-2008 09:53 AM
