Reattaching Towel Bar - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-06-2010, 10:27 AM   #1
Exclamation
reattaching towel bar
towel bar was knocked off wall by falling cabinet. wall is ceramic tile. how can i reattach the bar
j45b46 is offline   Reply With Quote
Old 03-06-2010, 09:25 PM   #2
DIY staff
Rewards Points: 7,174
A picture would help--We don't know how the old one was attached---
Some are held with screws into anchors
Ceramic ones are usually glued in place with silicone,--Mike--
Old 03-07-2010, 11:38 AM   #3
reattaching towell bar to ceramic tiled wall
towel bar was knocked off wall when cabinet fell over and hit it. how can it be reattahed,
Old 03-07-2010, 09:13 PM   #4
Special bit for drilling into ceramic tile
Here are some options:
There is a special bit if you need to drill new holes into ceramic tile Sort of looks like a pointy spade. If the tile is badly damaged and you didn't want to repair it you could mount the towel bar to a piece of wood and then cover the damaged areas. I've used shelving boards for this as well as nicely finished wood depending on the area. Shelves are quick cause they are fully finished on all sides and strong enough when you bolt the rod back to it. Regular drywall screws into studs. Cover the holes with the colored sticky dots that match the shelving.
Molly bolts are another option. I'd get the ones that have wings when you tighten them as opposed to the plastic sleeve that goes into the hole. go back into the prior holes if the wall wasn't too damaged. If it is just a little damaged buy the biggest molly that will fit your mounting bracket for the towel bar
Epoxy or silicon
Moving the towel rod to someplace else
Calling a tile guy
a picture would get you better advice
Five Arrows is offline   Reply With Quote
Hydronic Towel warmer install question bigbluedude HVAC 5 02-13-2010 08:02 AM
Towel rod and toilet paper holder dnbreaks Remodeling 4 01-30-2010 04:24 PM
bathroom towel racks ramonakc Interior Decorating 5 04-19-2009 02:59 AM
Question on Hanging Towel Racks sbattisti Interior Decorating 13 02-17-2009 12:24 PM
Removing Towel Rack to paint bathroom bigbearok Painting 3 02-12-2009 06:40 PM
