Reattach Aluminum Siding - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-26-2012, 12:00 PM   #1
A section of my aluminum siding was pulled off while doing some work on my bilco hatchway door. How might I go abour reattacing this section?
gilbo125 is offline   Reply With Quote
Old 03-26-2012, 12:35 PM   #2
Rewards Points: 13,712
Your going to have to pick up one of these.
http://images.search.yahoo.com/image...mb=cpCLpHoH11V
Lowes and HD will have one.
Start on the left and pull down on the zipper tool and press in with the palm of your hand on the siding and work your way to the right.
Even then aluminum sidding is a real challange to get to go back together.
gilbo125 (03-26-2012)
Old 03-26-2012, 12:56 PM   #3
Tom Struble's Avatar
Rewards Points: 2,002
looks like the panel just below it is not nailed,see how the seam is?
i think you need to lift up the unhooked panel SLIGHTLY push down the panel so the seam lines up and get some nails in the flange
then try and lock as Joe suggest
Tom Struble is offline   Reply With Quote
Old 03-26-2012, 12:58 PM   #4
Rewards Points: 2,238
What "joecaption" says -
Using a "zip" tool on aluminum siding is more difficult than on vinyl siding.
For aluminum, we use 2 or 3 "zip" tools, and usually 2 people.
rossfingal
rossfingal is offline   Reply With Quote
Aluminum siding not matching after Door install alcopaulic Building & Construction 1 09-07-2011 08:46 PM
Nothing Under Aluminum Siding dkel22 General DIY Discussions 9 09-30-2009 03:40 PM
Aluminum siding over existing old wood siding. timothevs Building & Construction 1 04-23-2009 04:13 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
