To Re-tile Or Leave Wooden Subflooring - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-26-2011, 08:48 AM   #1
Rewards Points: 321
to re-tile or leave wooden subflooring
Hi Floor People, I have removed the original, very-thin tile and adhesive off a 75-year-old kitchen floor, and the "underwood" looks great. (I don't know if that's the subflooring or not.) Is there any reason why I can't just sand the wood and put Varathane over it? I don't know if the original (linoleum?) tiles were put down just for looks or for functional purposes. I would like to leave the wood -- unless there's a good reason why I shouldn't? Jean
DIherself is offline   Reply With Quote
Old 04-26-2011, 09:45 AM   #2
DIY staff
Rewards Points: 7,174
Jean---Take a picture and post it---- Often older homes had maple kitchen floors--they can look fine when refinished, Other have fir flooring ---a bit soft and dents easily,but looks good when finished.
What color was the glue? Often the old black 'cut back' adhesives contained asbestos --extra caution needs to be taken when sanding that---Mike----
Old 04-26-2011, 09:48 AM   #3
Still Learning
you can sand and refinish. my house was built in the 1950's. when I pulled up the carpet there was hardwood. it waamthe origional floor. I had to replace a few boards but it was well worth the trouble, it looks wonderful!
thehvacguy is offline   Reply With Quote
Old 04-26-2011, 10:45 AM   #4
Rewards Points: 321
thanks Bud and Mike
I got the black adhesive up by hand -- just poured water on it, let it sit, and it melted whatever the black is, and I just scraped and scooped and wiped up the porridge. No sanding at all. I discovered that way accidentally one morning when the water heater spilled out overnight. I think it's pine (The floor is in Floorida).
Old 04-26-2011, 11:21 AM   #5
DIY staff
Give it a try in a small section----Do protect the area and put fans in the window--wear a respirator-
If you have access to a belt sander and a palm sanded (random orbit is best) try sanding and finishing a sample spot----
If you like the looks---call a floor finisher---Usually $2.00 a square foot or there about for sanding and finishing.---Worth the expense I believe. Doing it yourself will cost about the same in my experience and it's not easy to get good results the first time you try sanding and finishing.
----Mike----
tpolk (04-26-2011)
Tile over Tile ?? Piney Flooring 17 02-06-2012 10:59 PM
porcelain tile on existing wooden deck monatex Tiling, ceramics, marble 1 04-12-2011 09:59 AM
Could use some help on ceramic vs duraceramic tile helpmike Flooring 17 03-29-2011 11:42 PM
Subway tile installation bigboyjoel Flooring 3 08-02-2007 08:15 AM
Tile roof questions/repairs help please xoroniox Roofing/Siding 3 12-17-2006 03:02 PM
