-   -   to re-tile or leave wooden subflooring (http://www.diychatroom.com/f15/re-tile-leave-wooden-subflooring-102757/)
DIherself 04-26-2011 07:48 AM
Hi Floor People, I have removed the original, very-thin tile and adhesive off a 75-year-old kitchen floor, and the "underwood" looks great. (I don't know if that's the subflooring or not.) Is there any reason why I can't just sand the wood and put Varathane over it? I don't know if the original (linoleum?) tiles were put down just for looks or for functional purposes. I would like to leave the wood -- unless there's a good reason why I shouldn't? Jean
oh'mike 04-26-2011 08:45 AM
Jean---Take a picture and post it---- Often older homes had maple kitchen floors--they can look fine when refinished, Other have fir flooring ---a bit soft and dents easily,but looks good when finished.
What color was the glue? Often the old black 'cut back' adhesives contained asbestos --extra caution needs to be taken when sanding that---Mike----
thehvacguy 04-26-2011 08:48 AM
you can sand and refinish. my house was built in the 1950's. when I pulled up the carpet there was hardwood. it waamthe origional floor. I had to replace a few boards but it was well worth the trouble, it looks wonderful!
DIherself 04-26-2011 09:45 AM
thanks Bud and Mike
I got the black adhesive up by hand -- just poured water on it, let it sit, and it melted whatever the black is, and I just scraped and scooped and wiped up the porridge. No sanding at all. I discovered that way accidentally one morning when the water heater spilled out overnight. I think it's pine (The floor is in Floorida).
oh'mike 04-26-2011 10:21 AM
Give it a try in a small section----Do protect the area and put fans in the window--wear a respirator-
If you have access to a belt sander and a palm sanded (random orbit is best) try sanding and finishing a sample spot----
If you like the looks---call a floor finisher---Usually $2.00 a square foot or there about for sanding and finishing.---Worth the expense I believe. Doing it yourself will cost about the same in my experience and it's not easy to get good results the first time you try sanding and finishing.
----Mike----
