Re-siding A House - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-02-2008, 08:46 AM   #1
re-siding a house
why do new construction houses for siding just get house wrap and than vinyl siding put up. In our quest to re side our house a few companies are going to tear old house wrap off and put new up and than side. I have even had three guys say they will put up a product called fanfold than side the house which is better house wrap or fanfold they don't house wrap just fanfold?
hobbyguy2002 is offline   Reply With Quote
Old 02-02-2008, 09:55 AM   #2
Remodeling Contractor
oldfrt's Avatar
Rewards Points: 186
Generally,we use fan fold to go over existing siding.
It gives the installer a level plane to apply his new siding .
House wraps are installed as a component in a wall system on newer well insulated homes,for the purpose of allowing any moisture to escape from the interior and cutting back on air infiltration.
Depending on the amount of insulation ,type of insulation,presence of an interior vapor barrier,the exterior of your house should be treated independently.
This being said,fan fold has a minimum R-value,so if the siding is being stripped,consider a thicker insulation.
oldfrt is offline   Reply With Quote
Old 02-04-2008, 02:48 PM   #3
Home Performance
HomeSealed's Avatar
Rewards Points: 710
Thats about it.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Replacing Wood Panel 4'x8' Siding Chevmann99 General DIY Discussions 5 10-02-2005 08:43 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
