-   -   Re-facing fireplace, several questions! (http://www.diychatroom.com/f15/re-facing-fireplace-several-questions-106335/)
6fthook 06-02-2011 08:33 AM
So we are planning on re-facing our fireplace with cultured stone veneer, and also possibly putting in a wood burning insert depending on money, and also hang a flat screen TV above the mantle. But we have several questions that we're hoping someone can help clarify for us.
The old fireplace surround I ripped out was painted wood, and have 2x4s underneath to hold it all together (shown in pics). I still have to rip out the hearth.
http://i221.photobucket.com/albums/d...e/DSC_0245.jpg
1. Is it ok to use wood to frame out a layout against the existing brick? If it is I was planning on making a wood frame with a mount for the TV, and then screw steel mesh over the wood frame to put the mortar on, and then the cultured stone veneer. I've read many people saying "NO" to this, as the wood has a chance to heat up and cause a fire. BUT the existing fireplace already had a wood frame with wood veneer above it? And also I've read several DIY articles and videos using a wood frame. Keep in mind I am keeping the brick chimney and just putting stone veneer on top, so that can act as a heat barrier. Also, is it ok to use wood to frame out the hearth? I plan on putting a slab of bluestone above it.
2. Can we remove the extra layer of brick surrounding the fireplace opening? It looks like they just put an extra layer onto the chimney, but I just want to be sure. I put a red arrow pointing to what I'm referring to:
http://i221.photobucket.com/albums/d.../DSC_02462.jpg
3. What is the two layers of concrete blocks for? Is there a reason why they are there or can I take it off?
http://i221.photobucket.com/albums/d...e/DSC_0248.jpg
Thanks for any help you can provide!
Blondesense 06-02-2011 11:07 AM
I'm no expert, but I did do a bit of research when we had a wood burning insert installed in our fireplace.
First, what kind of fireplace do you have? Wood burning, gas, propane, electric? It might be helpful to add a pic with the doors open.
Second, if you are seriously considering an insert, I would suggest going to a couple of websites (we went with Lopi) and see what hearth requirements they have as far as construction and size.
6fthook 06-02-2011 06:46 PM
It is a wood burning fireplace. Here are some pics of the inside:
http://i221.photobucket.com/albums/d...e/DSC_0261.jpg
http://i221.photobucket.com/albums/d...e/DSC_0258.jpg
http://i221.photobucket.com/albums/d...e/DSC_0256.jpg
Bud Cline 06-02-2011 06:57 PM
The very first thing you must do is to make up your mind what you want to do. There can be a huge difference between a "REAL" fireplace and an insert when it comes to modifying things.
The cement blocks are (at this time) a major structural component of your fireplace, again you need to first decide which way you are going.:yes:
6fthook 06-02-2011 09:49 PM
Very good point! We have decided to get a wood burning insert, more specifically the Quadra-Fire 3100i AC (http://www.quadrafire.com/Products/3...od-Insert.aspx). The local dealer said this would be the best one for our house. Thanks for the help so far, and any additional you can provide!
6fthook 06-08-2011 08:06 PM
Ok, forget the old questions. New question:
Can I add a layer of bricks to the chimney to be on the same level as the layer around the firebox? Then put veneer stone (probably cultured stone) over the brick? For the hearth I was planning on bricks with bluestone on top, and then veneer stone on the sides.
The thing I'm worried about is the weight of all of this. Is this an issue?
Thanks for any help.
jomama45 06-10-2011 02:57 PM
That's probably the best plan yet. You could also just use a full veneer stone or brick instead of the two layers. Experience tells me that there very well COULD be enough foundation left below (currently hidden by hearth) for all of it to bear on with out any worry. You'll need to take off the hearth first though.
Bud Cline 06-10-2011 06:41 PM
Yow...My guess is that is one heck of a fireplace and there is plenty of foundation to support anything you have suggested so far.:yes: Check it out to be sure as j suggests.:)
6fthook 06-10-2011 09:14 PM
Thanks guys, tomorrow I will tear up the hearth and see what is underneath there.
So you're saying if the chimney is built up from the house foundation all the way up to the hearth, I'm good to go as far as adding significant weight to the chimney? BUT if underneath the hearth is just a wood frame, or just cinder blocks on top of the hardwood floor with tile on it, then it's a no-go as far as adding that much weight?
Is there another option to have it extend into the living room a little more?
This is the new look we are going for:
http://i221.photobucket.com/albums/d...acepicture.jpg
6fthook 06-12-2011 07:36 AM
I opened up the right side (while looking at it) of the hearth and here is what I found:
http://i221.photobucket.com/albums/d...e/IMAG0097.jpg
http://i221.photobucket.com/albums/d...e/IMAG0098.jpg
Didn't have enough time yesterday to rip it up completely because I was finishing some drywall in the kitchen. The tile on the fireplace is a pain in the A** to chip away at. Any suggestions for that?
I'm guessing the gravel is laying on top of the rest of the chimney foundation? What do you think? If that is the case, it means I can build up another layer of brick and then do the veneer stone on top without fear of too much weight, correct?
Bud Cline 06-12-2011 11:32 AM
I have always wondered why people that take pictures of their projects think the pictures must be close-ups as if we were splitting atoms or something. Back up about ten feet and take another picture of the whole area like the earlier photo that shows the windows. I have no idea what I am looking at in those last pictures.:)
6fthook 06-12-2011 08:35 PM
haha ok, I will get some farther away shots when I rip it open. The opening I made was very small and I just stuck my phone in there for the pic
6fthook 06-19-2011 03:09 PM
So here it is:
http://i221.photobucket.com/albums/dd257/niskyne/02.jpg
Where the red arrows are pointing, those are supported by the hearth, which is supported by the lower 2x4's on the wall, and also a few bricks underneath.
Here's some more pictures:
http://i221.photobucket.com/albums/dd257/niskyne/04.jpg
http://i221.photobucket.com/albums/dd257/niskyne/05.jpg
http://i221.photobucket.com/albums/dd257/niskyne/01.jpg
Here's underneath the fireplace/chimney in the basement:
http://i221.photobucket.com/albums/dd257/niskyne/03.jpg
Bud Cline 06-19-2011 05:39 PM
No surprises there that I can see.:)
So now what?
What was the question?:)
6fthook 06-19-2011 07:46 PM
I want to add another layer onto the brick to have it stick into the living room a little more, then add veneer stone on top of that to make it look good. I also want to put a bluestone mantel a foot above the fireplace opening. Then for the hearth, I wanted to stack brick or cinderblocks, put a bluestone slab on top, then veneer stone around it.
I just want to confirm that the existing chimney can support all the additional weight. Also, what do I do with the gravel/rocks? What is the best way to build the hearth over that?
Thanks for all the advice so far! Also thank you for the advice in my thread about drywall, very helpful!
