RBB Boards In House Instead Of Sheetrock - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-27-2009, 10:51 PM   #1
RBB boards in house instead of sheetrock
Greetings.. i am rebuilding from Katrina. I want to use RBB untreated yellow pine inside of my house instead of sheetrock. I do not plan to paint it. I kow the 4 by 8's are 5/8 thick and heavy. CAn i get away with this? I am ok of my house looking rustic. I do not want thin paneling on my studs and i like the idea of strength in the wood. I do not want to paint sheetrock.
Any advise ?
Hershey is offline   Reply With Quote
Old 02-28-2009, 11:42 AM   #2
Rewards Points: 5,336
What is an RBB board? Is this plywood?
Ron
Old 02-28-2009, 01:08 PM   #3
Drywall contractor
Rewards Points: 1,070
Reverse Board & Batten. It's meant to be used as an exterior siding (yes, basically plywood). You CAN use it if you choose, unless there's some building code in your area that says you can't. That said, it's an awfully rough surface for an interior application. I guess it's a matter of personal preference.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
replumbing an old house simonfrog Plumbing 7 01-30-2012 04:45 AM
Mounting a flatscreen TV on a sheetrock wall TanMan Building & Construction 14 02-16-2009 04:26 PM
Studs showing (bulging) through sheetrock js1971 Building & Construction 2 09-03-2008 06:48 AM
No House Wrap On New House JoeZ430 Building & Construction 34 11-29-2007 10:51 AM
sheetrock cieling? old house jamesdart General DIY Discussions 4 10-09-2006 03:36 PM
