Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 12-09-2012, 10:00 AM   #1
RAW EDGE ON SINK COUNTER TOP, silicone to seal??
The sink counter top is made of what I think is particle board. There is the ?typical? raw edge underneath the lip....there were many "Beards" located there...like stalactites....LOL... I literally had to shave them off (with a vacuum ! that brown dust gets everywhere..)...I guess it is the particle board swelling due to water or moisture dripping under that edge. It also rains down "brown dust" whenever a draw or cabinet is opened and closed... into my silverware etc....
Could I use silicone and just paint it under that edge?...
I have food grade silicone sealant for another project because it is about the only "caulk" I can tolerate (due to many allergies)...
Is this nuts? ...would there be a safety issue ? could the dried silicone caulk start raining down into my silverware draw and cups and plates? if so is that a problem?
any help appreciated
vi_lontano is offline   Reply With Quote
Old 12-09-2012, 10:10 AM   #2
AHH, SPANS!!!
Hi, Scrape the spot before you add the silicone. in fact, silicone might not stick as well as a construction type adhesive would or use the adhesive first with another coat of silicone afterwards. the problem is, it is trying to adhere to a crumbly surface so squeeze the adhesive up in there good so it can grab and I have seen the infamous brown particle dust in kitchens when the drawers are opened,happens a lot.
hand drive is offline   Reply With Quote
The Following User Says Thank You to hand drive For This Useful Post:
vi_lontano (12-09-2012)
Tags
raw counter edge, seal raw particle board, silicone
Kitchen sink faucet - putty or silicone, and where? nthdegreeburns Plumbing 11 07-24-2012 04:45 PM
attaching countertop analogmusicman General Discussion 22 08-10-2008 12:53 PM
Recaulking Bathroom Help RaeEllen Remodeling 9 07-25-2008 11:23 PM
Caulking around kitchen sink deeaa Remodeling 8 07-13-2008 04:12 PM
Applying laminate to waterfall edge on a counter top. lmpasker Carpentry 2 04-02-2008 07:34 PM
