Range-hood: Safe Distance To Run Ductwork? - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-04-2007, 03:43 AM   #1
Question
Range-hood: safe distance to run ductwork?
I am about to do a kitchen remodel and one thing I plan to do is add either a rangehood or a microwave rangehood. The stove is on an interior wall, and the hood would put a vent about 8 feet from an exterior wall. I'm planning to run a vent up into the attic and across to the outside wall, but that will end up pushing air about 10-15 feet (from hood to outside air). Is that too long of a distance to expect from a rangehood fan?
The other option would be to go straight up and out the roof, but I really think cutting through the roof should only be done if it is the last resort.
brockangelo is offline   Reply With Quote
Old 07-04-2007, 11:17 PM   #2
Rewards Points: 5,336
You need to look at the instructions on the unit you're installing. Each will have parameters of install. You're calculation of linear feet will not be calculated the same as, "duct run feet". A 90 degree elbow will add 5 linear feet to this calculation. Each unit will have a maximum recommended "duct run feet"
Check out each unit you might buy on the manufacturers website and pick the one that will work with your setup.
Ron
range hood vent vinman Roofing/Siding 6 05-07-2012 02:23 PM
custom range hood weekend warrior 1947 Carpentry 5 05-25-2011 07:59 PM
noise from vicinity of range hood squished18 HVAC 8 04-20-2010 01:15 PM
duct a range hood into garage? jimb317 General DIY Discussions 8 01-30-2008 08:41 PM
Can I Wire a range hood to an exhisting outlet? skellies Electrical 2 05-09-2006 05:06 PM
