Range Hood Exhaust Run... - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-20-2013, 06:41 PM   #1
valcarmo72's Avatar
Range hood exhaust run...
I have a microwave oven/ Exhaust fan that is currently set to recirculate the air...which does absoloutley nothing at all. I wanted to flip the fan on the unit but the kitchen is located almost in the center of the house. Therfore I would have to run 18 feet of rigid duct to exhaust the hot air. Is there a max amount of length you can run and also is the normal single wall tin exhaust good enough...? I can't go up because it is on the first floor...only straight across in the cieling with one 90 at the begining of the run...
Thx for the help....
valcarmo72 is offline   Reply With Quote
Old 02-20-2013, 08:32 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by valcarmo72 View Post
...but the kitchen is located almost in the center of the house.
What is UNDER the kitchen?
Old 02-20-2013, 08:33 PM   #3
valcarmo72's Avatar
Basement...thought of that but I thought u can only go up and out and not down..
Don't know?...ask someone...
Old 02-21-2013, 07:39 AM   #4
Rewards Points: 3,130
I suspect that like dryers, exhaust hoods have a maximum length for the exhaust run. Probably varies by manufacturer and/or model. But I have a gut feeling that 18 feet is much too long. The exhausted air really isn't very hot, so I see a big potential for grease condensing in the pipe.
Old 02-21-2013, 07:52 AM   #5
MarginallyQualified
Basement... I thought u can only go up and out and not down..
Originally Posted by md2lgyk View Post
I suspect that like dryers, exhaust hoods have a maximum length...
Correct.
Which is where the supplemental exhaust fan comes into play.
LINK
Old 02-21-2013, 08:21 AM   #6
valcarmo72's Avatar
What do mean supplemental...? Like a fan on the closest exterior wall type...?
Old 02-21-2013, 08:40 AM   #7
valcarmo72's Avatar
Inline fans in the duct work? Will it not build up with grease?..
Old 02-21-2013, 12:15 PM   #8
I would've thought so too. But based on the info at TarheelTerp's link, it's apparently OK.
Old 02-21-2013, 03:22 PM   #9
valcarmo72's Avatar
Wow totaly missed the link....LOL. Thx
Old 02-22-2013, 04:38 PM   #10
GBrackins's Avatar
Rewards Points: 2,108
length of vent is determined by the manufacturer. they determine this by the size of the vent and the amount of air the exhaust fan can move per minute. Go on the manufacturer's website and see what they have listed.
Good luck!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
The Following User Says Thank You to GBrackins For This Useful Post:
valcarmo72 (02-23-2013)
Old 02-23-2013, 11:41 AM   #11
AHH, SPANS!!!
Rewards Points: 1,166
the best exhaust that we used was a roof fan mounted version. totally quiet at the hood when on full blast and pulling all kinds of air, really neat! if trying to pull to much air over a long run of space a supplemental blower will be need to pull the air, grease is part of the system in a kitchen and the fan filters are for the grease- change the filters when needed
hand drive is offline   Reply With Quote
The Following User Says Thank You to hand drive For This Useful Post:
Range Hood Exhaust brevace Kitchen & Bath Remodeling 1 02-20-2013 03:00 PM
fantech outside mounted range hood fan carpdad Appliances 0 11-29-2012 12:29 PM
range hood opening is bigger than range hood jacks16 HVAC 2 06-23-2011 06:19 AM
Backdraft, Cold Air and Ice from Range Hood and Bath Fan Passion4Heels HVAC 13 08-19-2010 07:00 PM
Island Range Hood? fromwithin Appliances 0 11-25-2009 10:45 PM
