Raising A Deck? - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-16-2010, 11:45 AM   #1
Raising a deck?
I am considering a project to extend an existing 12'x14' deck on the rear of our house by about 20 feet (making it about 12'x34') to meet a deck that wraps from the front to the side of the home.
The decking on the back is severely weathered due to the previous owner's failure to maintain it, so I plan on replacing the decking, and probably the railing. My problem is that the deck on the rear of the home currently uses 2" planks, and the side deck uses 5/4"
Should I attempt to raise the existing frame, rip shims from composite decking, or just build the extension with an ever-so slight slope (3/4" over 15 feet) to meet the existing side porch?
BONUS QUESTION:
Are my 2x8 joists on 24" centers acceptable for 5/4 planks, or do I need to double them up (maybe with 2x6 between)
echase is offline   Reply With Quote
Old 03-16-2010, 02:38 PM   #2
Household Handyman
Rewards Points: 1,408
You are doing well by pre-planning, most don't. I'm missing one dimension here, the height of the deck framing of the back deck vs. the height of the framing of the front deck. ME--I would make these deck heights even after tearing off the old boards. I would not consider raising the deck. I would add some type of PT trimming, lattice pieces, something which will support the new 5/4 decking. It sounds as if you are planing on using composite decking. Not used much around here if exposed. Too much heat, weather problems. Too many discussions here on composite decking "mold/spotting" problems.
I would also put the 2x6's in, I never frame a deck less than 16" on centers perpendicular to the run of the decking.
David
Old 03-16-2010, 02:50 PM   #3
Thanks David!
The surfaces of both decks are currently equal, but one uses 5/4 one has 2" planks, so the one with the 2" planks (which will be discarded) is framed about 3/4" lower.
I'm leaning toward framing the connecting section at an angle to avoid adding what would effectively be a large shim on the top. I think this slight angle (3/4" drop over 15") would be imperceptible if it weren't for the siding behind the ledger... even then, I don't know that it will be noticed.
Im close to Atlanta, so I share your weathering concerns. I wasn't thinking of composite for the decking, just for the shims. (It would clash with my cedar siding)
Old 03-17-2010, 02:55 PM   #4
One thing to keep in mind. Your deck framing (spacing) composite decking will need a shorter on center then the current 2" decking or it will be wavy. I think the small slope over the new section of 20 feet is your best bet.
Brad Talent is offline   Reply With Quote
Concrete Pillars Raising Deck Ladybear Building & Construction 7 09-23-2009 04:31 PM
Building a new deck......suggestions? thoughts? Rhizzlebop Building & Construction 38 06-24-2009 06:07 PM
Post detail for raised covered deck jogr Building & Construction 3 05-16-2009 08:46 AM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 12:17 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
