Raising Ceilings - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-26-2012, 07:30 PM   #1
raising ceilings
we are flipping a house and are wondering if we can vault the ceilings or if they could maybe be raised they are 8 ft now
vince3201 is offline   Reply With Quote
Old 03-27-2012, 06:19 AM   #2
Can it be done, anything can be done with time/money. But if you have a house with standard framing, it will be costly and require a major redesign.
Old 03-27-2012, 06:40 AM   #3
Ole Wood Worker
BigJim's Avatar
Rewards Points: 540
It can be done, just be sure your walls are tied together so they don't spread, or make sure the ridge is supported. If the roof is trussed then the answer is no. Other things to consider is insulating the ceiling/rafters and where are the heat and air ducts going to go if they aren't in the floor. You will need to rewire also.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Coffered ceilings and adjacent hallways... Georgefloorman Carpentry 3 03-01-2012 07:51 PM
insulation in slanted ceilings dhonn Insulation 10 05-05-2011 12:38 AM
Install Siding before Raising Wall stubits Building & Construction 18 04-06-2010 08:53 PM
Covering Radiant Heat ceilings. Hockeynews Remodeling 3 04-10-2009 08:23 AM
Raising The Ceilings propain Building & Construction 2 06-28-2006 05:33 PM
