Raised Home, Need An Outdoor Type Ceiling - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-19-2009, 05:04 PM   #1
Raised home, need an outdoor type ceiling
My home is a camp built within 25 feet of a river.
It's build up 9 feet on pilings with a cement driveway poured beneath.
Though the home itself has vinyl siding, the contractor left the ceiling beneath covered with blue board insulation which comes apart with every hurricane or severe wind which whips beneath the house.
So I need to finish it out and then am going to mount some ceiling fans to make it a comfortable place to hang out in the shade. I've already got a bar, tables and grills in place but the blue panels look terrible and don't seal, allowing wasps and such to move into the cracks for nests.
So the question is.... what's the best way to finish it? I'm not convinced more vinyl is the way to go. I even thought about doing something as simple as hanging thin plywood and painting it white. That would be the easiest thing to do but not sure it compares on cost.
I've attached photos, one of which is post Hurricane Gustav so you can see the problem I speak of. The other was taken after we got snow (pretty unusual here) but it shows the type construction and the area I'll be working on pretty well.
Can anyone make any suggestions?
Thanks in advance for your help.
mcstraycat is offline   Reply With Quote
Old 06-20-2009, 09:05 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 606
Ayuh,... I did about the same thing on 1 of my houses,...
I used steel roofing/ siding....
Old 06-22-2009, 11:18 AM   #3
Wow.
That sounds pricy.
But I'm sure it holds up well.
Old 06-22-2009, 01:56 PM   #4
Renovation Contractor
Paragon's Avatar
Rewards Points: 150
MCCAT,
I could expound on options for your project but I think I will digress and simply post a couple projects for you to consider. I think you can take a look at these and reply accordingly. This is a fairly common outdoor project and th results are stunning. There are many variations on the material you opt to use and most are cost driven. I think if I were you (I understand money does not grow on trees however don't skimp on something that is going to cause you problems down the road in rot and insect infestation.
Take a look at these links and give us some feedback and we can fine tune your project from there.
http://www.thisoldhouse.com/toh/how-...174950,00.html
Norandex and other outside siding companies have variations of this project if in fact you want to go with something along those lines...
http://www.norandex.com/Products/Fin...h%20Panel.aspx
and here is another very popular approach and that is a T & G ceiling You could do this with any species and don't have to go with a 1 x 8
http://video.bobvila.com/m/21319568/...ch-ceiling.htm
Good luck be safe and let us know how it goes!
James D. Van Raden
Owner, Paragon Renovations Moorhead, MN/ Fargo, ND
"Committed to providing the finest renovation services available"
Paragon is offline   Reply With Quote
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 08:42 PM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 07:32 PM
False ceiling... Why? jpelzer Building & Construction 3 06-03-2009 09:01 AM
Owning a home (not a mobile home) on leased land? Badfish740 Off Topic 11 03-30-2008 10:34 AM
A facelift for your home Grumpy Remodeling 0 07-07-2004 08:43 PM
