Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 07-26-2009, 03:54 PM   #1
They're all fixer-uppers
J187's Avatar
Quick question about tiling around shower valve
When I am tiling around my mixing valve, do I cut around the whole thing, IE the big black plastic circle or just the part that actually protrudes from the wall where the handle goes?
Thanks.
J187 is offline   Reply With Quote
Old 07-27-2009, 07:14 AM   #2
The black plastic is just a guide for finding locating the fixture. It comes off and gets tossed. You may be able to make the hole smaller, so test assemble the rest of the fixture. Generally though, that is what you cut around.
Old 07-27-2009, 09:28 AM   #3
J187's Avatar
Really? I'm confused... the instructions didn't seem to mention unscrewing the plastic and removing it afterwards... I can't on the website right now to double check because its down... Are you saying I should have removed the guide and my underlayment should have been just cut around the valve part?
Old 07-27-2009, 11:04 AM   #4
Nia
You can make a template the size of the tile out a piece of paper.
Place the paper over the tile , push it over the pipe and it will rip the paper.
Then make sure everything is lined up properly and draw a circle with your drill attachment. Place the paper template over the tile and cut with our circle drill attachment. You may have to sand the inside a little if you're cut is off, or use your tile nippers.
Hope that helps.
Nia is offline   Reply With Quote
Old 07-27-2009, 11:36 AM   #5
J187's Avatar
Thanks NIA - my question isn't so much about how to do the cutting, rather what to cut out... I was asking if I should cut the tile just around the part that comes out of the wall or if I should cut around the whole plastic piece...
Old 07-27-2009, 01:36 PM   #6
RDS
I had the same question when I put Durock around my tub recently, and I asked my plumber how big to make the hole for the valve, and he said to do exactly what you did -- follow the plastic.
RDS is offline   Reply With Quote
Old 07-27-2009, 03:18 PM   #7
Nia
I cut around the piece that comes out of the wall.
Old 07-27-2009, 04:32 PM   #8
J187's Avatar
Did this apply to the tile as well? Thanks
Old 07-27-2009, 04:52 PM   #9
RDS
Yes, it did. I think the idea is that the escutcheon will be of a diameter slightly wider than the hole, so it covers it (maybe verify this by measuring) and then you caulk it to the tile. But maybe different valves and their trim have different requirements -- that was just my situation.
How to diagnose gas valve problems Nestor_Kelebay How To Guides 27 03-07-2013 03:17 AM
Shower Arm Question brakea Plumbing 2 01-02-2009 06:58 PM
Moen shower valve question tmbrink Plumbing 5 12-14-2008 11:17 PM
Electrical Box near Shower Valve dasajame Electrical 3 07-07-2008 07:46 AM
Question about shower valve? Rick Bruner Plumbing 3 03-23-2008 11:09 PM
