Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 07-13-2008, 12:34 PM   #1
Questions on drywal setup for hanging kitchen cabinets...
Hi,
I'm installing some new kitchen cabs and have two questions.
1: Is it absolutely necessary to get moisture resistant drywall for this? I've already bought the regular stuff. Don't the backsplash and tiles actually take care of the moisture issue?
2: Is it necessary to finish the drywall with tape and putty if it's just going to be behind the cabinetry?
Thanks in advance for any advice!
ericblair is offline   Reply With Quote
Old 07-13-2008, 12:55 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
You'll be fine with standard S/R.
Not necessary.
- Build Well -
Old 07-13-2008, 02:06 PM   #3
Thanks alot
Old 07-13-2008, 04:45 PM   #4
One thing we did when hanging walls(8') that had upper and lower cabinets was to put a 2' piece up top, then a full 4' and then another 2' piece down the bottom. That way there will be no seam in your backsplash.
jerryh3 is offline   Reply With Quote
Old 07-13-2008, 09:06 PM   #5
K&B Remodeler/Tile Guy
angus242's Avatar
I always have my drywall guys tape and put 1 coat of compound on the seams in places that won't be seen. Helps stop potential air transfer between sides.
Standard drywall is fine.
If you haven't installed the drywall yet, perhaps you can review where your cabinets are going to go. Sometime you get a cabinet that is only over a single stud. In that case, I like to add backer material between the studs so I can have at least 2 locations to screw each cabinet into (aside from upper/lower).
Angus
angus242 is offline   Reply With Quote
Old 07-14-2008, 05:49 PM   #6
As a standard practice I put blocking in the walls where cabinets are attached. This way you balance the screw pattern to the load, not to the available studs.
Ron
Removing textured finish from kitchen cabinets jbwaechter Remodeling 6 10-04-2010 02:12 PM
Are kitchen cabinets standard sizes? Yeti Remodeling 8 01-30-2009 03:20 AM
Installing kitchen wall cabinets higher than spec recommendation? alexz General Discussion 14 07-21-2008 12:32 AM
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 04:21 PM
Kitchen Cabinets and Walls ththomps Remodeling 4 09-18-2006 11:23 PM
