Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 03-19-2007, 08:31 AM   #1
Question on installing cabinet door hardware
We are painting our kitchen cabinets. The doors currently have exposed reverse bevel hinges. I want to change over to hidden hinges.
Do I install the hinges first on the inside of the cabinet doors and then onto the cabinet frame, or vice versa?
TIA!
Boatnuts is offline   Reply With Quote
Old 03-19-2007, 08:32 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
TIA!
As you partially stated: "....install the hinges first on the inside of the cabinet doors..."
- Build Well -
Old 03-19-2007, 09:04 AM   #3
Thanks for the quick reply. How do I then ensure the doors are all installed at an equal level?
Old 03-19-2007, 10:16 AM   #4
Measure up and make reference marks on the cabinet side and the doors. Duplicate those reference makes for each door and each opening. Use those reference marks to install each door hinge in the same corresponding locations...
- Build Well -
Old 03-19-2007, 10:46 AM   #5
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
There are also jigs for this. If you are doing a bunch it may be worth the investment.
See
http://www.leevalley.com/hardware/pa...=3,41241,55420
and
http://www.rockler.com/ecom7/findprod.cfm?&sku=5878
http://www.rockler.com/product.cfm?page=10250
Also read this
http://www.rockler.com/faq/choosing_concealed_hinge.cfm
And, while you are at it, Rockler and LeeValley are the best mail order hardware sources around. Get their catalogs. Also, if you are a tool junkie get the LeeValley tool catalog.
Brik is offline   Reply With Quote
Installing Kitchen cabinets help helpless handyman Carpentry 16 07-07-2007 07:12 AM
Novice question: Installing windows in wood sided home...(pic) Dr. Jim Building & Construction 5 07-06-2007 07:33 PM
question on installing stucco siding? Rusty Bottoms Building & Construction 7 10-27-2006 03:26 PM
Question on installing floating hardwood floor loragail Flooring 7 10-23-2006 10:06 AM
Installing a ceiling fixture Cregan Electrical 3 02-08-2004 10:43 PM
