Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 04-24-2009, 09:04 AM   #1
Question about replacing interior doors
The wife is now in full nesting mode and wants all projects done before the baby gets here.
When replacing doors, do I measure the door itself or the frame? We will be purchasing pre-hung doors.
newbieowner is offline   Reply With Quote
Old 04-24-2009, 11:03 AM   #2
You measure the rough opening to be sure. Don't forget to measure the jamb width as they can differ, especially in older houses and modular houses.
Ron
Old 04-24-2009, 11:58 AM   #3
measure the door itself ,these all should be whole numbers no fractions. common sizes are 24"28" 30" 32" 36" by 80" in ht. Like ron said measure jamb width the thickness of wall. Most of the homes built in the last thirty years will be 2x4 or2x6 so the jambs will be either 4 9/16" or 6 9/16"
eidol is offline   Reply With Quote
Old 04-24-2009, 02:11 PM   #4
When I measured the doors i got all sorts of numbers. All of them fractions.
Old 04-24-2009, 02:54 PM   #5
The actual door size will vary a bit from manufacturer to manufacturer. That's why you measure the rough opening, because that's the measurement you will give to the person taking the order. Along with the jamb measurement. Measure all the jambs, don't do a few and figure they're all the same.
Ron
Old 04-26-2009, 10:19 AM   #6
thanks.
Question regarding replacing a fiberglass tub in a apartment! Chris112 Plumbing 7 01-27-2009 03:19 AM
Replacing Sill plate Question Electromech31 General Discussion 6 09-17-2008 10:08 AM
question about replacing a shingle roof w tin Moparman Roofing 4 06-01-2008 01:45 AM
One furnace question and one thermostat question lh0628 HVAC 4 10-11-2007 11:17 PM
