Question About PVC Wainscoting - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-14-2009, 12:31 PM   #1
Sephora's Avatar
Rewards Points: 150
Question about PVC Wainscoting
I like the look of it and that is rot fee, etc. We would use it for our bathroom.
Question is we don't want to take down the 6x6 tile. Do you think we can put this up over the tile?
Can we use "liquid nails" It says we could for easy installation on their website.
http://www.plastproinc.com/pdfs/Plank_f&B_final.pdf
Also, do you think they make taller sizes?
Sephora is offline   Reply With Quote
Old 04-14-2009, 12:38 PM   #2
Remodeling Contractor
You can buy this in 4' X 8' sheets and yes you can glue it to tile.
Old 04-14-2009, 12:42 PM   #3
Sephora's Avatar
Rewards Points: 150
I can buy it from HD or Lowes in 4x8 sheets and then just cut them down? Will they have the base trim and the chair rail too? Seems like all you have to do basically is glue downt he base board, pop in the wainscoting and then secure at the top with chair rail.
Thanks for your help.
Old 04-14-2009, 07:53 PM   #4
Rewards Points: 264
They have 8' planks as well as the standard wainscot length(32" i think?).
Another brand to consider is Azek. Probably won't find it at the box store, usually at a lumber yard.
If you glue it to the tile the top rail will be off the wall by the thickness of the tile and will have to deal with that gap. If the gap is large the box stores usually have some PVC mouldings in different profiles that might help kill out the gap.
7echo is offline   Reply With Quote
Old 05-20-2009, 02:08 PM   #5
Rewards Points: 14
Other Brand
Check out http://www.parklandplastics.com/polymax.shtml. They sell different sizes.
annekreel is offline   Reply With Quote
Question about Wainscoting kits Krichton General DIY Discussions 8 12-29-2009 08:18 AM
Wainscoting? kcrossley2 Carpentry 11 10-24-2008 06:27 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
Basement vapor barrier question rob7young Remodeling 2 04-13-2008 09:10 AM
One furnace question and one thermostat question lh0628 HVAC 4 10-11-2007 10:17 PM
