Putting Windows In An Existing Brick Wall - Remodeling - DIY Chatroom Home Improvement Forum
Old 08-06-2009, 02:29 PM   #1
239 Adventurer
jbaker1516's Avatar
Putting windows in an existing brick wall
In my house reno, I plan to put windows flanking the fireplace. The R.O. for the each window is 14" wide (see attached pic); they will be non-opening. My question is this - with a 14" opening, and about 5-6 (based on attached picture, haven't actually counted yet) courses of brick above each, do I need a lentil, or not? If so, is the proper procedure to remove the bottom row of bricks that will remain above the windows, insert the lentil and then re-brick that row ... or some other method? Thanks.
This was previously posted in the Construction forum (no replies). I have since deleted it from there and moved to this forum ... hopefully I hear from someone here.
jbaker1516 is offline   Reply With Quote
Old 08-07-2009, 06:22 AM   #2
You definitely need something to support the brick above the opening. A good mason should be able to do it without tearing out above.
But check local code on your framing around the fireplace. Combustibles have to be a certain distance from firebox opening, it looks a bit close.
Peplacing rotten framing against brick wall minnjh Carpentry 2 07-01-2009 03:21 PM
Exterior Brick Wall Seperated from Home mrhonest Building & Construction 3 01-15-2009 05:06 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
How do I install new windows? RickT Carpentry 17 10-12-2006 06:06 PM
