Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 02-13-2010, 10:18 PM   #1
Putting up a drywall ceiling...will need to drill into concrete.
Hi all,
I did a search but couldn't find anything related to the topic so I thought I would ask the question directly. We are looking to finish our basement in our condo and it currently has a concrete ceiling. We are planning on drilling into the concrete to put up the framing so we can attach drywall to it. We are located in Toronto and hoping to double check that this (i.e. drilling into the concrete ceiling) isn't for any reason against building code.
Thanks in advance!
netvivi is offline   Reply With Quote
Old 02-13-2010, 11:59 PM   #2
jlhaslip's Avatar
can't see why you couldn't do that, but consider gluing the board directly to the ceiling maybe?
plumbers and electricians hang stuff off ceilings all the time.
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
Old 02-14-2010, 06:18 AM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Use construction adhesive and tapcon screws. Use strips of appropriate thickness plywood to reduce splitting - when attaching to the concrete.
If there are ridges on the concrete from the forms = chip, or grind those flat - to allow the wood to lay flat.
- Build Well -
Old 02-14-2010, 11:41 AM   #4
Definitely clear this with the condo board.
Your ceiling is your neighbor's floor.
There is serious liability here.
Dairylander is offline   Reply With Quote
Old 02-14-2010, 11:46 AM   #5
must mean his neighbor lives with him since its his basement
The older I get the better I was
Old 02-14-2010, 11:55 AM   #6
Hah! Missed that.
So you have a townhouse then?
Is it pre-cast spancrete?
Poured in place?
What does it look like from below?
Old 02-14-2010, 02:27 PM   #7
Hah! Missed that.
Poured in place?
I am not sure what kind of concrete it is. I guess the concern isn't so much about the condo board as they didn't seem to have an issue but just wanted to make sure there isn't some obscure rule in the Toronto building code preventing us from doing this...as we're trying to get permits.
Old 02-14-2010, 07:13 PM   #8
if all the floors are fabricated the same as in concrete then there should be no problem hanging drywall along with lights etc
wet attic insulation and ceiling drywall rojas66 Drywall & Plaster 4 03-04-2009 04:33 PM
Using drywall for Drop Ceiling rickkeeter Drywall & Plaster 8 02-13-2009 08:52 AM
Replacing 12" ceiling tile with drywall housefixin Remodeling 5 09-09-2007 04:00 PM
Basement Ceiling Drywall- ? When wall is concrete H Thomas Building & Construction 5 04-20-2006 10:20 AM
Basement Ceiling- Combo of Drywall and Drop ceiling? H Thomas Building & Construction 5 03-27-2006 09:27 AM
