Putting R25 Footer Sill - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-04-2007, 10:03 AM   #1
Question
would like to insulate the sill above my footer and would like to use R 25, would I save on my Energy Bill and keep the house warmer in the Winter and cooler in the Summer?
Rifeman is offline   Reply With Quote
Old 09-04-2007, 12:01 PM   #2
Rewards Points: 5,336
The insulation will help more with the cold then the heat, but it will help. You probably won't see a large difference in the energy bill, but there will be less drafts as a result.
Ron
Old 09-09-2007, 09:04 PM   #3
I assume when you say R25 you are referring to fiberglass batts. The sill/foundation area typically allows alot of air flow. In this situation I would consider an application of spray foam. Expanding foam does alot better job sealing cracks and crevices than fiberglass does. Keep in mind that a well sealed basement or crawlspace may allow previously unnoticed mosture problems to come to light and some type of controlled ventilation may become necessary which is not a bad thing.
scrapiron is offline   Reply With Quote
Old 09-09-2007, 10:58 PM   #4
Scrapiron, I think he means against the rim joist, but sealing the space between the sill plate and the concrete foundation with foam is the way to go.
Ron
how to fix rotted sill plate carole2cd Building & Construction 7 03-26-2011 07:19 AM
Requirements for Sill anchors and ledger boards? sandyman720 Building & Construction 7 08-20-2007 07:56 AM
Aluminum Door sill and Concrete Dragon Building & Construction 2 01-06-2007 01:55 PM
Bathroom shower sill installation question bocci Remodeling 2 07-23-2006 01:31 PM
Undercut footer billinak Building & Construction 3 03-18-2005 07:34 PM
