Putting Feather-edge On Self-leveling Compound - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-05-2009, 07:12 AM   #1
Rewards Points: 248
putting feather-edge on self-leveling compound
How soon after pouring SLC over CBU do you start feathering the edge? Does it have to set up a bit first, or do you start feathering while it's still runny?
diy888 is offline   Reply With Quote
Old 03-05-2009, 07:18 AM   #2
The time between being able to finish the edge and it being too hard to work is short, but as I recall, about 15-20 minutes. Trying to do anything while still soupy won't work. But you should not install tile tight up against a wall anyhow, you need a 1/8-1/4 expansion gap.
Old 03-05-2009, 11:42 AM   #3
Rewards Points: 5,336
Start feathering it when it stops expanding over the floor.
Ron
Old 03-05-2009, 03:50 PM   #4
Rewards Points: 248
Thanks for the replies, guys. I'm doing a spot-pour because there's a low corner, and feathering the edge towards the center of the floor, rather than against the walls. It may be a little hard to tell when it stops flowing because it has to flow "uphill". I've never worked with it before. What's it feel like in the phase after runny/pancake-batter? Does it get tacky?
Old 03-06-2009, 07:30 AM   #5
It goes from soup to hard fast, once it starts to set. Just don't walk away for long.
Old 03-09-2009, 11:24 PM   #6
Read the instructions and use the primer.
Mop in Hand is offline   Reply With Quote
Old 03-10-2009, 07:02 AM   #7
Rewards Points: 248
Of course.
The instructions don't address this specific issue, however.
Self leveling compound bcarwell Flooring 4 09-07-2012 01:27 PM
floor leveling compound geraldS Flooring 4 03-01-2009 09:20 AM
Ardex SD-F Feather Finish and SLC diy888 Remodeling 1 01-18-2009 11:21 AM
Self Leveling compound on hard wood floors?? Tbizzy2 General DIY Discussions 3 05-22-2008 12:11 PM
Shingle Installation with F5S Standard Drip Edge ShortEdged Roofing/Siding 32 02-15-2008 03:10 PM
