#1 |
Coconut Pete's paella!
Putting a door where this window is .....
We were going to put our door to the deck where there was no door at all due to the fact that the giant closet in our den would have made a nice mudroom.
Right now we are considering putting it here instead - seems like it would give the house better "flow". Ceiling height may be a bit of an issue w/ the header if we go with a full double door due to header size. We were thinking maybe it would be possible to just put a regular 36" full view door where the big window in the middle is. Of course it comes down to whether or not there is actually support where the red lines are. When a window like this is framed, is it normal to have studs all the way through or are these things usually installed as one giant unit? This is in an addition from approx 1950 - 1955 (nobody really knows) |
#2 | |
STAFF
Putting a door where this window is .....Quote:
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Jim Last edited by BigJim; 05-09-2011 at 10:44 AM. |
#3 |
There is an overhang of about 8" or so, but nevertheless I agree that a pan under the door is a good idea.
That window is right around 36" - I need to pull some trim and see what kind of opening I can actually create there, but I suppose worst case I could buy a 32" door instead. We just used the deck for the first time yesterday and realized how much we need a door there. Not only that but the kitchen is coming out soon and the grill will be the only source of "hot" cooking - well except for the microwave - for a few weeks. The 36" door seemed like a nice compromise between going all out w/ double french doors and not doing anything. Either way though - I'm feeling pretty good about it - Thank you. Last edited by CoconutPete; 05-09-2011 at 01:22 PM. |
#4 |
Well - got the ductwork moved today, so there's really only one thing left to do and that is to start chopping!
One decision I am left with is what to do w/ the short piece of wall under the door? I built the deck so I'll have about a 6" step down onto it just because of snow etc. Between that 6" and the 2" or so the siding extends below the deck level (it's free standing so there's a tiny gap between the deck and the house). I found examples of the siding left there - is that the normal thing to do? Does anyone build it differently? |
#5 |
Not so new
Pete....How wide is that center glass?
#6 |
Putting a door where this window is ..... |
#7 |
Not so new
[quote=CoconutPete;644391]Ceiling height may be a bit of an issue w/ the header if we go with a full double door due to header size. We were thinking maybe it would be possible to just put a regular 36" full view door where the big window in the middle is.
34.5" RO is a 32" door. Of course it comes down to whether or not there is actually support where the red lines are. When a window like this is framed, is it normal to have studs all the way through or are these things usually installed as one giant unit? I would'nt consider it normal. I think you'll find thats one window or 3 windows put together on site. Certainly there are no studs there. IMHO that opening will become to small once you do frame a rough opening. |
#8 | |
Mod
[QUOTE=12penny;668905]
What I’m seeing is a single unit under one header for a 6/0 opening. Plenty of room to do what he wants. He should be able to just pop off some trim inside and determine what he has.
A Picture Is Worth A Thousand Words Especially In The DIY Chatroom -NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State. |
#9 |
Not so new
Dohhhh! The way I read it he wanted to put a single door in between the 2 casements.
#10 |
Correction time: My bad, I had too many measurements in my phone and posted the wrong one.
12Penny: You are right - I do want to put a single door in between the two casements. My bad if I worded it the wrong way. Also ... about the measurements. I had too many notes written down and gave you the wrong number. The distance in between is actually 37 3/4". Since the rough opening needs to be 38.5" for a 36" door I believe the 32" door would be the better/more realistic choice allowing me just under 2" on either side to "beef up" the frame. Here are some pics to help explain. |
#11 |
The window opening could be framed a few ways.
There could be one header across the whole opening. Or There could be one header over each window. Find out what you have before ordering a door. Looking at it, there's only enough space for 1, 2x4 between the side windows and the picture window. So it's either framed incorrectly or there's one header across the whole opening. Open both sides of the RO and take a measurement to determine what you want to do.
Ron "They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." B. Franklin 1759 |
#12 |
Rainy day tomorrow = Chop time!
Will be back w/ pics after I rip off the trim and open the wall. Thanks again. |
#13 |
OK, did some demo today. Looks like there is one big header across the whole thing.
Clearance might be an issue here. As you can see, the 82.25" Sweet spot is 2.25" into the header. This got me thinking though .... the 6' wide french doors seem to call for a rough opening height of 80" instead of 82.5. That would leave me only needing to find 0.25" somewhere. I think between the two layers of linoleum tiles on the floor alone I can find that. The last pics is of the bottom - The studs are where the blue painters tape is. I can't make sense of the placement of them. |
#14 |
Andersen might make a reduced height door. Check with them.
I don't understand what you mean by this, "The studs are where the blue painters tape is. I can't make sense of the placement of them." What studs are you speaking about? There looks to be a vent there. The studs might be the rough opening the ductwork is attached to.
#15 | |
Below the window there are 3 studs. I have marked the location of them w/ those 3 small pieces of painter's tape. The duct is "dead". I had the line re-routed. The tape is over it so my Yorkie doesn't get adventurous. Several 7' wide french doors seem to e 80" instead of 82" so I am leaning in that direction. |
| Display Modes | |
| Condensation on fiberglass window frame | creamaster | General Discussion | 11 | 01-05-2012 08:42 PM |
| my fix for rotting outside sill on wooden window | guest | General Discussion | 6 | 11-06-2010 03:58 PM |
| New window frames? | PCMLR | Carpentry | 2 | 10-08-2010 12:23 PM |
| window performance question | renbelle | Building & Construction | 4 | 10-06-2010 03:25 PM |
| Bathroom window issues? | Mantaray14 | Remodeling | 11 | 12-04-2009 08:40 PM |
