Put Fascia On Old Windows - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-23-2008, 04:28 PM   #1
put fascia on old windows
Hello,
We own 8 rental properties. I would like to put fascia on the old windows instead of installing new ones. I got some estimates, it costs us a $3,000 for each properties. I am wondering could my husband and I do it ourseleves?? thanks..
Sherry
sunpalozzi is offline   Reply With Quote
Old 07-23-2008, 07:13 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Pictures and more descriptions would help us understand what exactly you want to do, and if it is do-able by you and your husband.
- Build Well -
Old 07-23-2008, 10:11 PM   #3
Registered User
Termite's Avatar
First of all, let's get your terminology right. Fascia is the board that sits on edge at your roofline and creates the transition from the soffit to the roof edge. The gutters mount to the fascia.
My guess is that you are talking about some sort of window trim or brickmould. The ease or difficulty of doing it will be determined by how it is built currently. There is a chance that it is a DIY project, but should only be undertaken if you are a competent carpenter. This project is not the place to learn how to correctly flash exterior trim, and mistakes will cost you in the long run.
Post some pictures so we can see what you've got, and we can go from there.
Old 07-24-2008, 09:43 AM   #4
puting "Aluminum trim" around the windows
Hi,
thank you for the replies. attached is a pic of one of the windows that need to be either painted or replaced or I am thinking to put the aluminum trims to cover up the current window trims.... After some researching, I made the decision to go with putting up the alumimum trims to cover the window trims up.. I watched enougth "HG TV" to sugguest my husband may be we can do it ourselves... thanks...
sherry
Old 07-24-2008, 09:21 PM   #5
Registered User
Termite's Avatar
I doubt you'll be happy with an aluminum cap over the existing trim. Have you located a source for such an item? If you were re-siding the house with a similar system, I would think it were feasible. As it is, my opinion is that you need to replace the wood trim. Aluminum is just a band-aid fix over something that really needs to be replaced to keep the house from rotting.
replace anderson windows hobbyguy2002 Remodeling 13 12-06-2009 10:34 PM
Fascia cover filled with water/ice causing leaks brianbh Roofing/Siding 10 02-11-2008 08:34 PM
First time vinyl siding newbie plus windows justdon Remodeling 9 02-06-2008 07:39 PM
new windows juliejules4 HVAC 12 12-06-2006 02:37 PM
How do I install new windows? RickT Carpentry 17 10-12-2006 07:06 PM
