Pull Down Attic Stairs HELP! - Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-22-2008, 06:06 AM   #16
Rewards Points: 99
Have tenatively settled on Rainbow metal telescoping attic stairs. Reviews suggest they are quite strong. My concern with stair strength results from our placement of utilities (hot water tank, a/c, etc.) on top of reinforced concrete "safe room" that is accessable through a walkway ifrom the garage ceiling.
If there's a better brand or alternative, would appreciate recommendations.
nicksteel is offline   Reply With Quote
Old 06-22-2008, 11:35 AM   #17
Rewards Points: 99
And................a solution!
My garage is 22'x22' with a 16' storage room and 6' lawn mower bay at one end. Kinda dawned on me that I could put about half the upper part of the stairs into the storage room, leaving floor space below, and the remaining part as a hinged swing down unit. This way I can have stronger, wider steps and can access by moving the mower. A door will conceal the lower stair when folded.
Pull Down Attic Stairs HELP!-untitled.jpg   Pull Down Attic Stairs HELP!-planz.jpg
Old 06-22-2008, 11:40 AM   #18
Rewards Points: 6,652
Now, that would work for you. As for the railings, they would have to be set up in a way that you can collapse them, which means removable pins, or move when you hoist the stairs with a winch. As for the winch type, an electrical can work, or you can use the type as found on Boat Trailers. You will have to use Bolts to secure the Risers and allow them to pivot, due to using hinges, can cause failure later on.
Old 06-23-2008, 02:23 PM   #19
Mold!! Let's kill it!
Rewards Points: 2,012
I had a set of fold up stairs in my shop for a long time. They were about 13 feet long, 30 inches wide with some heavy hinges on one end. We had rigged up a small electric hoist to put it up and down. The backs of the stringers were sheeted with plywood painted to match the ceiling. You have to be careful that you have a limit switch to stop the hoist when it reaches the top. The hoist was geared low enough that it held the stairs in the up position without any kind of lock. After some remodelling, it wasn't needed anymore and I did away with it, but it worked fine for about 15 years. It was kind of nice in the summer. You could run it down about 6 inches and turn on the exhaust fan in the attic and cool the shop.
Old 03-15-2009, 02:15 PM   #20
Rewards Points: 99
Attic Stairs
House is nearing completion and I have to decide on the stairs to access a large storage area over my garage. Trying to find the safest, most stair like pull-down unit. I am currently looking at one piece slide down units.
I am also building a hoist similiar to a versa-lift to hoist items into the garage attic storage area.
I need advice on which stair units to look at. I'm sure some of the members have experience with these. This is a retirement home and, planning ahead, we want to install something strong, safe and convenient to use.
Old 11-24-2010, 03:59 PM   #21
You should place the opening in another location such as a hallway, or if you garage is attached, that may work. As for the height, you are able to get extensions for the stairs for cases such as yours.
_________________
Kate Ross
Attic Stairs
katerossmail is offline   Reply With Quote
Old 11-24-2010, 04:25 PM   #22
Rewards Points: 99
Attic Hoist and Stairs
This is an old thread, but thanks.
We had the hoist fabricated and installed along with a set of Rainbow Prestige attic stairs I purchased on Craigslist for $400. They are outstanding.
http://rainbowatticstair.com/
Attic Smell from A/C - I'm at wit's end! cidsamuth HVAC 19 08-23-2016 05:36 AM
Changing from carpet stairs to wood stairs DIY_user Remodeling 16 07-29-2010 07:16 PM
Proper Attic Insulation reikiray Roofing/Siding 5 08-04-2007 10:59 AM
Air duck from basement to the attic MageMinds HVAC 2 04-26-2006 12:41 AM
