Protecting Hardwood Floors - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-27-2011, 11:16 AM   #1
Protecting hardwood floors
What is the best way to protect hardwood floors in a room where I will be gutting?
Mattcall is offline   Reply With Quote
Old 06-27-2011, 11:42 AM   #2
Architect / Carpenter
If the hardwood is in good shape and you don't want to have to sand and refinish, I would recommend covering with the floor with red rosin paper (tape the seams to keep it in place), then a layer of carpet padding and finally a layer of 1/2 plywood or OSB. This will protect the floor from scratches and dents should any larger chunks of wood, plaster or drywall (or tools) fall on the floor.
carpitect is offline   Reply With Quote
Old 06-27-2011, 02:36 PM   #3
Too Short? Cut it Again!
They make a material you can paint on and when it cures it forms a rubberized barrier that goes a long way toward protecting floors. The above approach works as well.
And here is one some sub-contractors fight me on tooth and nail at times. I have a keep clean clause or two embedded in all my contracts. I expect contractors to bid the time it takes to sweep up after themselves (not just plunking stuff down floor vents) into their work for me and to perform such tasks so the jobsite stays relatively clean and safer. You'd think their mothers were asking them to straighten up their rooms or something. But if the nails are swept from the floor they are not going to get ground into it as people walk all over things.
Old 06-27-2011, 04:19 PM   #4
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
+1 on that.
Whatever you do on top of the paper is going to depend on the tools etc. you will be dragging into that room.
CoconutPete is offline   Reply With Quote
Easy maintanence and child friendly Hardwood floors? gante Flooring 11 04-12-2016 12:20 PM
Old Glue on Original Hardwood Floors! gh4444 Flooring 5 02-11-2012 01:13 PM
New buckled hardwood floors Angela3511 Flooring 12 07-16-2009 08:58 PM
5 Ways to carry on your hardwood floor shining brightly John_smith Flooring 3 02-24-2009 12:56 PM
Hardwood floors: Removal of carpet staples, dried paint, and a discoloration problem proofer Flooring 7 03-01-2008 08:06 AM
