Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 11-10-2012, 02:26 PM   #1
Proper Insulation/Membrane for basement walls.floor
Hello everyone! I'm looking for some advice on my basement remodel as I seem to have a situation I haven't been able to find an answer for.
Some background:
The house was built in the mid 60's and I have been living in it for 3 years now. It seems at some point there was water 'issues' in the basement that have been professionally addressed with a retrofit french drain and some outdoor measures as well. Since I have lived here, there has been no bulk water problems at all. The basement will however get pretty humid in the summer & we have used a de-humidifier.
Goals:
I'd like to remodel about 80% of the ~800sq ft space into living space and would like to mitigate any possible chances for water/mold. Reading through the forums and the building sciences website I think I have a decent plan, but I don't feel right about one issue i'm having with the french drain retrofit. There is a membrane associated with the french drain protruding a few inches from the poured concrete floor around the perimeter of the entire basement:
Here is a cross-section of how I plan on dealing with it:
So I was wondering what everyone's thoughts were about using the 6 mil poly to bridge the membrane gap under the bottom plate of the perimeter walls? There will be an air gap that i don't think I will ever be able to avoid because of the existing membrane!
Thoughts?
NovaBiele is offline   Reply With Quote
Old 11-19-2012, 03:34 PM   #2
Anyone have any comments?
I'm getting ready to start ordering materials after the holiday, and would really appreciate some feedback.
I'm a bit concerned about that air gap around the existing membrane.
Also, The Delta-FL installation directions do not mention any XPS. I'd like to avoid using it (height clearance issues) but if it is at the expense of a very cold floor do to poor insulation I'd reconsider. My finished flooring will be some form of synthetic carpeting (over 5/8 OSB over Delta-FL).
I'v also decided to use a sill foam insulation between the poly & bottom plate 'just in case' water penetrates it will not wick up.
Old 11-19-2012, 04:05 PM   #3
Do you have water issues or a cold concrete floor? I am in the middle of finishing of my basement and am not doing anything besides carpeting the floor. All my landscaping has been dealt with and I have no water issues.
Also, I went with 1" XPS. I monitored the humidity levels over this past summer and was not or the 40-50 % humidity so the smaller sheet was not an issue. Obviously 2" would be better, but for $$$ and space constraint I went with 1".
B
Beepster is offline   Reply With Quote
Old 11-19-2012, 04:54 PM   #4
There hasn't been any water issues since i've owned it. We've had some pretty bad rains...the kind where there is standing water in my shaded back yard for a few days and the basement has stayed dry and I have never noticed the sump pump running. I did need to move the sump piping at one point and it was full of water, so it must have been running at one point.
The basement does get very humid in the summer. We run a dehumidifier with a 50% duty cycle to keep it bearable.
The floor gets pretty cold in the winter, I've walked on it barefoot no problem, but my wife cant stand to. I feel like the DeltaFL air gap + OSB + padding + carpet would be enough but was just totally guessing at this.
Old 11-19-2012, 09:10 PM   #5
Trucon01's Avatar
Off topic question... Where can I get that black dimple / drainage board? I've only seen online where I can buy it in bulk when I only need about 30ft or so...
Basement Demo started Jan 2012:
Bathroom demo started Feb 2013:
Trucon01 is offline   Reply With Quote
Old 11-19-2012, 09:53 PM   #6
Average Joe/ex-Navy IC3
gregzoll's Avatar
Insulate & air seal your Rim & sill spaces. Also if the windows are original, replacing them will also help with the hot & humidity. Do you have any ducting feeding that space now, to help & heat & cool?
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Tags
basement, french drain, insulation xps, remodel, vapor barrier
proper size furnace and proper size air cinditioner? wshomers7 HVAC Site - PROS ONLY 0 06-15-2012 09:02 PM
Proper way to install chimney pipe in metal building roof jonblack Building & Construction 15 01-31-2012 11:50 AM
Proper drain and vent help needed papisox Plumbing 17 11-03-2010 09:52 AM
proper way to terminal romex entering drywall Red Squirrel Electrical 10 03-03-2010 01:43 PM
Help! What is Proper Way to Install Manufactured Stone? EricW Building & Construction 3 01-07-2007 04:56 PM
