Proper Construction Of Shower Knee Wall - Remodeling - DIY Chatroom Home Improvement Forum
Old 08-10-2010, 08:57 AM   #1
Proper construction of shower knee wall
I am re-tiling our shower and tub surround, which are separated by a knee wall. What is the proper way to construct/waterproof the knee wall? I am thinking of installing Hardibacker on the front and back, constructing a slightly pitched top out of mortar, applying Redgard over all of it for waterproofing, and tiling over that.
Will this give me sufficient waterproofing? Do I need to extend the PVC shower membrane up and over the knee wall? The shower was not constructed that way initially.
Thanks!
lawyer101 is offline   Reply With Quote
Old 12-17-2013, 11:46 PM   #2
Should be fine. Redgard is all the rage now!
Big44dog is offline   Reply With Quote
Old 12-19-2013, 09:47 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 290
Lawyer,
A liquid membrane such as Redgard does the job if applied as directed. Be sure to apply the correct wet film thickness to achieve the correct dry film thickness. That is the biggest mistake with these products and one reason I use the Kerdi system.
How are you building the lower part, the floor and curb?
Jaz
JazMan is online now   Reply With Quote
Shower Head w/ Hose But Hangs On Wall... Not spout? flipjarg Plumbing 2 02-11-2010 10:19 AM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 01:39 PM
Building knee wall in basement, best approach? RyanD Building & Construction 6 07-04-2009 02:07 PM
Water seeped through tiles in shower, wall ruined, need help. doogie88 Building & Construction 39 10-07-2008 05:13 PM
V shaped wall construction brosnt1 Building & Construction 3 02-08-2006 03:00 PM
