Product To Cover Stair Risers - Remodeling - DIY Chatroom Home Improvement Forum
Old 08-24-2012, 11:51 AM   #1
product to cover stair risers
I bought my first house, the only carpet in the house was on the stairwell. It was covering oak stair treads and plywood(?) risers. The risers have tons of cosmetic damage to them (50-100 staple/nail holes per riser and Two different colors of paint).
What is the best product that I can use to cover the risers? I would like something paintable or at least a veneer product that offers a choice of colors. I do not want to try to match the existing wood treads with a similar material riser.
Looking for a simple affordable solution.
Thanks.
karen1 is offline   Reply With Quote
Old 08-24-2012, 02:41 PM   #2
AHH, SPANS!!!
Rewards Points: 1,166
maybe a 3/8" AC plywood will work, you do not want the riser to be to thick because of the tread overhang...
hand drive is offline   Reply With Quote
Old 08-24-2012, 03:36 PM   #3
they make an adhesive backed veneer
http://www.woodsmithtips.com/2010/06/10/easy-veneering/
http://www.oakwoodveneer.com/pressur...ve-veneer.html
Old 08-26-2012, 01:39 PM   #4
Too Short? Cut it Again!
Wood epoxy paste sanded smooth? Woodepox from Abatron is pretty easy to work with. You can tint it or paint it with no problems. Just trowel or drywall knife it on, let it set and sand. Must do some surface prep of course so you get adhesion but this is true of anything you pick.
http://www.abatron.com/building-and-....html?vmcchk=1
Tags
refinish , repair wood risers , stair riser , veneer
using Lowes edge precision flooring Andy McDonald Flooring 68 03-17-2012 02:42 PM
interior stair risers pushed in davesink Carpentry 2 09-27-2011 04:25 PM
Stair Tread and Risers tuchodi Flooring 0 08-03-2011 09:38 AM
Basement Decorative Wood Wall Cover popping up tk3000 Building & Construction 8 10-29-2010 01:17 PM
