Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 04-10-2009, 02:04 PM   #1
Question
Problen with hanging heavy draperies in sheetrock metal studs wall.
I am trying to hang both sheers and heavy draperies over a span of 100 inches. The rods are made of wood and both have a diameter of 2 inches. I used two double wooden brackets – one on each end. The problem with the wooden brackets is that the two small screws pulled out of the wood on one side, and the bracket itself pulled out of the sheetrock wall. The bracket was attached using two small screws and two wall anchors. Needless to say, all came falling down with the pole impacting my wood floor!!! My thinking now is slanted towards the purchase of three metal double drapery brackets that will accept the 2 inch pole. Ideally I want to screw three equally spaced metal brackets into the metal studs and not use wall anchors. My problem is that the metal studs don’t line up at either end or exact middle of the area above the draperies. I’m thinking of attaching two or three horizontal (100”) 1 x 2’s to the wall into the metal studs then screw the three equally spaced metal brackets into the ends and middle of the 1 x 2’s. My goal is to make drapery supports that will support my weight (145 lbs.)!!! Can anyone tell me another way of accomplishing this so that the heavy draperies WILL NEVER fall to the floor again? I rather not use wall anchors. Please help. Thank you.
Fixitgeorge is offline   Reply With Quote
Old 04-11-2009, 02:03 PM   #2
Drywall contractor
You probably have answered your own question. I would use some sort of wood attached to the metal studs. Perhaps just one piece, say a 1"x4" or 1"x6". Make it decorative by cutting some type of pattern with a jig saw across the top and maybe use a router to add a nice rounded edge all the way around....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Hanging a Heavy Mirror frapha1 General Discussion 6 01-03-2010 12:21 PM
Hanging dry wall??? gone_fishing Remodeling 10 12-01-2008 04:39 PM
Hanging heavy pictures in an old house BlackRichard Carpentry 4 05-07-2006 09:35 PM
Hanging cabinets on cinder block wall ponchoman1 Remodeling 2 04-25-2006 10:34 PM
