Problem Glass Tile Shower - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-11-2007, 01:24 PM   #1
I recently installed glass tile on a shower that was completely redone. The shower originally had a metal lath slab floor that we replaced it with a rubber membrane and mud pack. We then put down thinset and laid the glass tile and then grouted the tile. We finished by sealing the tile. Now the bottom of the shower and the walls about 8 inches up look water logged through the glass. Does anybody have any ideas of what might have happened and how it can be resolved?
Thanks,
Pete
robin2107 is offline   Reply With Quote
Old 03-11-2007, 01:35 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
I'm not a plumber, and I am not a shower enclosure expert.
But:
What are the wall's materialss under the tile comprised of?
Could you have a leak in your line somewhere in the wall?
Check your drain, could water be escaping thru that somehow?
- Build Well -
Old 03-11-2007, 01:38 PM   #3
The walls are green board. It's almost like the floor is absorbing water.
Old 03-11-2007, 02:07 PM   #4
ohhh....not good....
- Build Well -
Old 03-11-2007, 02:16 PM   #5
As you might have read already on this site....a vapor barrier on the rough framing with cement board installed over it along with silicone is really the way to go when installing shower tile work.
But, that's 'water' under the bridge... or in this case...under the tile?
Sorry to make a 'pun' at your expense....but it was there and I had to ... er....um .....sorry...
Anyways - did you roll the membrane up the wall? Did you make sure that it was not cut or penetrated at all any where along the pan area and up the wall?
- Build Well -
Old 03-11-2007, 02:20 PM   #6
There where no punctures and the membrane went up the wall to about the point that it looks water logged - 8 inches.
Old 03-11-2007, 02:30 PM   #7
Wow...I think that tells you something...the water is being held at that 8 inches because of the 'basin' that was created with the membrane. So the membrane is holding it.
One area to check is where your tile meets the shower pan itself...
This article talks about some factors/area to examine with a leaky shower:
http://www.thisoldhouse.com/toh/know...218790,00.html
- Build Well -
Old 03-11-2007, 02:31 PM   #8
Also,
You could send a PM to R&D Tile, a member on this forum site....regarding this issue.
- Build Well -
Old 03-11-2007, 02:40 PM   #9
Thanks a bunch. I'll read the article right away.
Old 04-23-2007, 09:19 PM   #10
The green board behind your tile is wicking water up from the pan. Simple as that. Green board shouldn't have been used, but the problem isn't that simple, even CBU and Hardi will wick, but not as bad. DensShield would have been a better choice.
Glass tiles require a bullet proof system to ensure no water wicks up behind them. This is going on in showers all over the country, but you can
t see through stone, cermaic and porcelain tile so nobody knows about it. Glass you can see through.
Time for a tear out unfortunately.
Mike Finley is offline   Reply With Quote
Another newbie building a tile shower ChadC Building & Construction 7 08-25-2008 03:58 PM
Shower Pressure Problem rob1970 Plumbing 18 03-10-2007 11:41 AM
Shower tile need some help here dirtyb115 Remodeling 2 12-23-2006 01:27 PM
tile shower help Atricaudatus Remodeling 13 04-01-2006 09:38 PM
