Prmier Old Plaster Before Patching? - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-04-2009, 09:12 PM   #1
--Bill
Prmier old plaster before patching?
Its been recommended to me that I prime my old paster with a shellac-based or alkyd primer prior to patching with setting compound. Is this extra step and expense necessary?
foothill is offline   Reply With Quote
Old 06-05-2009, 12:42 AM   #2
Since nobody else posted up, I guess I will. I'm far from an expert, but have learned my lessons the hard way. I use a deep sealer and a bonding agent (from now on, read my post minor catastrophy) anytime I do plaster repairs.
Plaster work is just too dirty and time consuming to skip any steps. In fact, in my experience, overkill is the best policy.
If in doubt I wash down the entire wall to remove as much wall paper paste, loose material and dust as possible and use plastic mesh or even metal mesh to reinforce problem areas.
IMO you have to figure it cracked for a reason. Framing does shift and shrink. Brick or block does expand and contract. Even dissimilar plasters expand and contract at different rates and/or absorb moisture in different quantities (humidity).
When patches are applied, the existing plaster can suck the moisture out of the patching material very quickly. This can cause cracks or mess with the bond. Though this seems to be less of an issue with improved materials in recent years.
Bigfoot is offline   Reply With Quote
Old 06-05-2009, 10:30 AM   #3
Mold!! Let's kill it!
Rewards Points: 2,012
I would not prime the old plaster first. It will inhibit the bond between the patch and the original plaster. You could dampen the surface of the old plaster to keep it fom drying out your patch too quickly if that's a concern.
Old 06-05-2009, 01:28 PM   #4
I'd done hundreds of patches with few problems, using just the plaster and water. Though thicker patches did tend to crack, if they were not sprayed or dampened every couple of hours, so they cure slowly. This seems less of an issue recently, the materials seem to have been improved some.
A deep sealer, helps keep patches from drying to quickly, soaks in and stabilizes the existing plaster and may also help with the bond. I spray it on with an old widow cleaner spray bottle.
Using a brush on bonding agent, for me at least, is more of a why not thing than a why thing anymore. A half gallon is cheap and goes a long ways and can be used for other projects.
Old 06-06-2009, 04:31 PM   #5
Rewards Points: 5,336
They have a product called, Plaster Weld, made especially for this task.
Ron
Patching plaster in bathroom foothill Remodeling 2 06-02-2009 01:50 AM
Plaster Walls - Did I screw up? jamiedolan Building & Construction 5 11-07-2008 01:10 PM
patching plaster skim coat thomase Building & Construction 2 06-30-2008 12:28 PM
Need help please asap...patching plaster pics attached mood Building & Construction 2 07-30-2005 11:06 PM
