Priming Knotty Pine - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-23-2011, 10:52 AM   #1
priming knotty pine
I've taken on the challenge of painting my knotty pine room. Its been sanded and I've used wood filler on the knots to fill in all the cracks. The reading i've done about this says to use 2-3 coats of oil based primer to prevent and stains showing up. I've done 1 coat using Kilz oil based. I was wondering if i did my next and last coat with latex primer if that would work also? As of know I see no knots through the primer. I am having a hard time using such a stinky product. I've always used no or low voc paints.
improvise is offline   Reply With Quote
Old 06-25-2011, 06:18 AM   #2
Kilz or Zinser latex primers work fine.
knotty pine vaulted ceiling raghib Building & Construction 32 05-09-2012 09:25 AM
Can't find studs behind knotty pine paneling David S General DIY Discussions 15 09-05-2010 05:56 PM
Knotty Pine mgortel Carpentry 5 06-21-2010 08:21 PM
HELP!!! Primed Knotty pine... needs to be unprimed! deke44 Painting 2 06-04-2010 03:44 AM
How do I remove dark staining on my knotty pine? Ajidahk General DIY Discussions 12 03-25-2010 01:14 PM
