Prime Before Patching On Drywall? - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-17-2007, 02:32 AM   #1
Prime before patching on drywall?
I recently removed the popcorn texture from my bedroom ceiling. I was wondering if I could prime the drywall before I patch any holes and imperfections. Or do I need to make the fixes before I prime it?
DIYScott is offline   Reply With Quote
Old 09-17-2007, 06:28 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Do your drywall repairs FIRST. You should definitely prime it after. Priming it before can cause issues with the way the compound adheres to the surface, among other things.
(It will also take longer for the compound to dry since the moisture content can't be absorbed into the ceiling due to the primer layer)
- Build Well -
Old 09-18-2007, 02:04 AM   #3
Thanks AtlanticWBConst. Started doing some patching tonight.
Old 09-28-2007, 09:19 PM   #4
Priming it after the repairs are made has another benefit. It allows you to see any defects that remain, so you can smooth them further.
Once I have taped and mudded drywall (normally two coats), I always prime it before doing the finish coat of mud. As I said, it definitely reveals the imperfections.
Handyman50 is offline   Reply With Quote
How many coats of prime require on new drywall? KUIPORNG Painting 23 02-26-2011 06:47 AM
General easy drywall question bigboyjoel Building & Construction 3 05-27-2007 08:52 AM
Patching drywall-where to place seam? AllGoNoShow Building & Construction 6 09-20-2006 11:02 AM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 05:47 AM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 07:11 AM
