Prepping Shower Window For Tile - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-04-2010, 08:13 AM   #1
prepping shower window for tile
Any suggestions on how to hardiebacker this window in order to tile it? My main problem is the jamb sticks out about 1/8" past the 1/2" hardiebacker. 3/8" furring strips underneath. Pictures attached.
prepping shower window for tile-window3.jpg   prepping shower window for tile-window1.jpg   prepping shower window for tile-window2.jpg
jbitt is offline   Reply With Quote
Old 06-04-2010, 08:52 PM   #2
kwikfishron's Avatar
Rewards Points: 760
I must be missing something.
It looks like to me you have plenty of room to surround and face your window with tile.
Your finished tile should end up being ” in from the outside of the window frame.
kwikfishron is online now   Reply With Quote
Old 06-05-2010, 03:29 PM   #3
i should've added more detail as to what i think my problem is :-). the window jamb sticks out about 1/16" to 1/8" beyond the 1/2" hardiebacker + 3/8" furring.
I guess what i'm trying to figure out is how to get the backerboard to cover the top and bottom gaps that are stuffed with insulation so that i can tile the window like in the picture attached. not sure if i should cut the jamb down so that backerboard will run right over the top & bottom gaps, fur out more, or if i'm just misunderstanding what i need to do in order to tile the window.
Old 06-05-2010, 08:10 PM   #4
Rewards Points: 760
After I posted I realized I could have been a little more clear.
As far as your sill sticking out to far and your 3/8” firing strips (that I can’t see) you need to get them out of your way. Sawzall is the tool.
After that, a table saw is the tool, so you can rip custom pieces to attach to the framing to get the finish framing you need.
Then you can install the backer and tile.
shower window farrington135 Remodeling 14 06-10-2012 09:17 PM
Waterproofing a shower window seacuke23 Tiling, ceramics, marble 3 08-24-2009 01:20 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
Shower in Window jchri66 Remodeling 1 05-27-2008 12:50 PM
Sorta waterproof window for OVER a tub shower bathroom justdon Remodeling 5 09-16-2007 08:27 PM
