Prefab Granite Overhang? - Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree2Likes
Old 04-20-2017, 11:50 AM   #16
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,444
Re: prefab granite overhang?
I am curious though as well exactly what goes under this mess.
Pugsy.....my project: Total House Rebuild Bungalow to Two Story
123pugsy is online now   Reply With Quote
Old 04-20-2017, 03:17 PM   #17
Rewards Points: 32
The only support is the wall cleat on one end and a half-wall on the other end that runs the full length minus ~5".
I made a crude diagram:
The builder is going to replace the cleat with a larger/longer one and install a couple of these underneath: https://www.counterbalanceshop.com/c...ket-10654.html
As well as put in a strip of plywood to fill the gap, tied into the cleat and those brackets, and finish/paint the underneath.
Is this sufficient or do they need to pull the top and put a new one in?
neird is offline   Reply With Quote
Old 04-20-2017, 03:18 PM   #18
Rewards Points: 32
Full length minus 10". Not 5". I can't edit my posts.
Old 04-20-2017, 03:45 PM   #19
Rewards Points: 32
Another diagram with proposed supports:
Will this suffice?
Old 04-20-2017, 04:18 PM   #20
123pugsy's Avatar
Will this suffice?
It will strength wise.
It sure looks like they will be ugly as heck if you're not building in cabinets under there.
Again, what exactly is this area?
Old 04-20-2017, 04:22 PM   #21
Rewards Points: 32
I thought I said already, but it is an peninsula/seated bar area. Open space is where chairs go.
We are considering putting in some shallow storage underneath there (still plenty of room for chairs), but I am more concerned with strength than looks at this point.
The Following 2 Users Say Thank You to neird For This Useful Post:
123pugsy (04-20-2017), MTN REMODEL LLC (04-20-2017)
Old 04-20-2017, 07:24 PM   #22
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 3,392
Neird..... Thanks... Now you're cooking....
That is a decent solution as to stability.
I would note, that if that front edge has been laminated out to 4cm (very common) that ply can be run all the way out to the edge. 3/4 ply is a little less than 2 cm.
I'm basically of the same thought as Pugs.... but as you point out, that is not your question/concern.
But YOU did well in questioning the integrity, and getting a satisfactory fix from the installer.
But remember....YOUR INSTALLERS did a krap job if they were going to leave that and walk away.
Watch them closely..... be sure they install the 24" angle iron and be sure they land them on studs and well secured with substantial lags/screws and not some drywall screws.
Good going
ZZZZZ likes this.
MTN REMODEL LLC is offline   Reply With Quote
Old 04-20-2017, 07:31 PM   #23
Neird... Sort of a peripheral question... but you called that pre-fab granite.
Normally pre-fab only comes in 25-26 inch depth.
By pre-fab ,, did you mean they fabricated it in the shop.... or you went to a granite supplier that sold the counter already made and finished....
Just curiousity.
Best
Old 04-20-2017, 07:54 PM   #24
Rewards Points: 32
When we ordered it they sold 25/26" piece finished on one side as well as 36" wide pieces finished on all sides.
safe granite overhang on island corner denemante Kitchen & Bath Remodeling 1 12-07-2012 06:13 PM
Granite Bar Overhang support LeviDIY Kitchen & Bath Remodeling 11 05-22-2010 11:41 AM
Granite counter top overhang Sumar Kitchen & Bath Remodeling 10 05-17-2010 04:36 PM
40" Granite overhang. cjsdad General DIY Discussions 17 08-28-2009 03:02 PM
Stonemark & Silestone Countertops......??? DepotDweller Remodeling 9 06-25-2009 11:44 AM
