pre-hung door installation
I am planning on replacing this door. This is an exterior door for my garage. The challenge is that the concrete step that the door is on is not exactly level at the door opening. The right jamb side is 3/8" lower than the left side jamb. What will be the right way to deal with this.
1) Shim under the sill? Then there will be a large gap under it.
2) The current door has the sill anchored tot he slab, but it does not seal under the door.
Reason: change title
