Pre-Hung Door Install: Before Flooring Or After? - Remodeling - DIY Chatroom Home Improvement Forum
Old 05-14-2012, 12:56 PM   #1
Pre-Hung Door install: Before Flooring or After?
I am updating a room and was wondering should I install the pre-hung door first or the flooring? The flooring is going to be either hardwood laminate or carpet.
Thanks in advance.
jabba is offline   Reply With Quote
Old 05-14-2012, 01:55 PM   #2
If your going with a hard surface, I would do it after. This way you will not have to notch the flooring around or undercut the jamb or casing. If you go with carpet that has a pile, I don't think it matters either way. The only issue I see installing it after, would be you maybe having to trim the length of the jamb a little to fit the rough opening due to the increased height from the flooring. But I dont even think that is likely.
SoCalLivin is offline   Reply With Quote
The Following User Says Thank You to SoCalLivin For This Useful Post:
jabba (05-15-2012)
Old 05-14-2012, 05:27 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,114
its entirely up to you, depending on who's installing the flooring. if your not very experienced with putting down flooring i would hang the door afterwords because if you dont know the little tricks to tuck flooring underneath a undercut jamb you'll have a really hard time
on a professional job, all the doors are hung first then cased. this is for timing.. by having all the doors and trim up first the painters can come in and spray everything out and get the first coat of color on the walls. then the flooring installers come in and do their thing.. baseboard goes down then the 2nd coat of paint goes on.. it reduces the chances of damage to the floors by putting them in as late as possilbe
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
jabba (05-15-2012)
Old 05-15-2012, 10:18 AM   #4
Rewards Points: 2,212
If you do it after you really need to account for unevenness in the floor.
I think with carpet do it first, hard flooring do it after.
mae-ling is offline   Reply With Quote
The Following User Says Thank You to mae-ling For This Useful Post:
jabba (05-15-2012)
Old 05-27-2012, 08:39 PM   #5
Usually flooring most of the time goes first.
Then you simply put your door jamb and trims on top of the flooring.
That it. Very simple.
Always try to keep it simple.
otch is offline   Reply With Quote
Lumber Liquidators Bud Cline Flooring 11 10-28-2011 02:00 PM
asbestos in our ripped up flooring?? 6fthook Flooring 16 07-29-2011 11:06 PM
Installing Hardwood Flooring on Concrete Flooring, Condo slickwilly789 Flooring 1 10-08-2010 08:53 PM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 08:00 PM
