Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 01-19-2012, 01:53 AM   #1
Pre Hung door bottom clearance
I have three 32 by 78 interior doors to install in my basement.
Rough Openings are 34 by 80 1/2
There exists no subflooring yet,only concrete.
My question is,I am looking to install a dricore subfloor,which is 7/8ths thick,after that how much clearance will I have to put finished floor on top before contact with the bottom of the door becomes an issue?
Thanks in advance for your inputs.
spring3100 is offline   Reply With Quote
Old 01-19-2012, 02:41 AM   #2
Retired carpenter
1 inch space between the floor and the bottom of the door is the standard.
abracaboom is offline   Reply With Quote
Old 01-19-2012, 09:51 AM   #3
STAFF
BigJim's Avatar
Deleted
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is offline   Reply With Quote
Old 01-19-2012, 10:08 AM   #4
Disabled wood vet
titanoman's Avatar
Install the door with pieces of sub and finish floor stacked under the jamb.
titanoman is offline   Reply With Quote
Height clearance for ceiling hung furnace acerunner HVAC 5 06-08-2011 12:27 AM
Sub panel clearance question Red Squirrel Electrical 2 05-09-2011 10:53 PM
Double Hung vs Single Hung CZSteve Remodeling 0 11-08-2010 08:29 AM
Furnace Clearance avtck HVAC 0 01-02-2010 10:13 PM
Masonite pre hung doors sticking hot weather Pawl Carpentry 4 07-08-2008 05:26 PM
