Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 03-15-2007, 01:07 PM   #1
Power painter ? worth or junk?
I am about to start painting... now .... I saw HD have those $100 to $200 electric power painter... are they good or junk... please advice...
they are hand held with a small bucket attach to hold paint... and a electric plug... type
not those monstor expensive sprayer....
I also saw those roll and paint stuff with push button pump, no electric power, are they good also?
and how about those paint tank sprayer requires a compressor, are those good too?
After some research on the internet, spot this guy
Campbell Hausfeld HV2000 High Volume Low Pressure Sprayer
I will probably go for it after approve from the Boss now she is back from US ....
Thanks....
KUIPORNG is offline   Reply With Quote
Old 03-15-2007, 06:11 PM   #2
I used a cheapy wagner mechanical sprayer before on a patio, worked ok... until a buddy tried to clean the thing with gasoline, then it caught fire and melted
I can't comment on quality but it was a lot to clean up, so I'd only recommend it for big jobs.
elementx440 is offline   Reply With Quote
Old 03-15-2007, 06:53 PM   #3
Eibwen
I bought one of those Wagner sprayers and it works but you have to mask the area and clean up overspray along with the sparyer when your done. Plus I dont think the amount of paint/quality of the finish is the same as doing it by hand.
If your painting an empty rental property maybe.. If its the home you live in and you want a good quality paint job you wont have to redo in a few years... Prime, then roll/brush a good quality top coat.
Sammy is offline   Reply With Quote
Old 03-16-2007, 09:07 AM   #4
thanks for the info.... the Boss didn't approve anyway... your info makes me feel better as I cannot purchase anyway...
Wiring for switched, split power outlets ELurie Electrical 9 06-21-2007 08:12 PM
Debugging Hot Water Heating System when on Standby Power hwitten Electrical 4 12-15-2006 09:47 PM
Running a generator for power outages tropic home Electrical 5 12-04-2006 09:22 PM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 02:55 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 11:23 PM
