Power painter ? worth or junk?
I am about to start painting... now .... I saw HD have those $100 to $200 electric power painter... are they good or junk... please advice...
they are hand held with a small bucket attach to hold paint... and a electric plug... type not those monstor expensive sprayer.... I also saw those roll and paint stuff with push button pump, no electric power, are they good also? and how about those paint tank sprayer requires a compressor, are those good too? After some research on the internet, spot this guy Campbell Hausfeld HV2000 High Volume Low Pressure Sprayer I will probably go for it after approve from the Boss now she is back from US .... Thanks.... |
I used a cheapy wagner mechanical sprayer before on a patio, worked ok... until a buddy tried to clean the thing with gasoline, then it caught fire and melted :jester:
I can't comment on quality but it was a lot to clean up, so I'd only recommend it for big jobs. |
I bought one of those Wagner sprayers and it works but you have to mask the area and clean up overspray along with the sparyer when your done. Plus I dont think the amount of paint/quality of the finish is the same as doing it by hand.
If your painting an empty rental property maybe.. If its the home you live in and you want a good quality paint job you wont have to redo in a few years... Prime, then roll/brush a good quality top coat. |
thanks for the info.... the Boss didn't approve anyway... your info makes me feel better as I cannot purchase anyway...
| All times are GMT -4. The time now is 01:49 PM. |
