Powder Actuated Hammer Tool Question? - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-24-2012, 09:21 AM   #1
Rewards Points: 89
Powder Actuated Hammer Tool question?
Hello everyone,
I'm trying to frame a basement but I can't get the nail on my nail gun to go through the concrete for the bottom beam. The concrete is so hard that the nails just popped up like curly french fried . Do I need to use the 22 caliber powder actuated hammer tool for the bottom 2x4 beam or I need a special type of nail for it? Can someone please help me?
Thank you everyone in advance!
bcdinh is offline   Reply With Quote
Old 07-24-2012, 09:28 AM   #2
Framing Contractor
Rewards Points: 116
Tapcon screws work really well. Sometimes the Powder tools work well, sometimes they don't. Shooting a framing nail into concrete is never the correct way to fasten the bottom plate.
sixeightten is online now   Reply With Quote
Old 07-24-2012, 10:02 PM   #3
Rewards Points: 512
what!?!? you are using a regular framig nailer to try to shoot into concrete!?! thats funny! you definitely need a powder actuated gun to shoot into concrete. you can also use tapcons like sixeightten said.
princelake is offline   Reply With Quote
Old 07-24-2012, 10:18 PM   #4
Rewards Points: 89
thanks guys! it looks like the contractor frame my basement used the regular nail gun nail. the actuated gun nail has a orange star but this one doesn't have one. does anyone know what type of nail is that?
Powder Actuated Hammer Tool question?-img_0946.jpg   Powder Actuated Hammer Tool question?-img_0947.jpg   Powder Actuated Hammer Tool question?-img_0951.jpg
Old 07-24-2012, 10:43 PM   #5
Haverhill Trade 1965
Believe it or not Max Air makes a high pressure air nailer / compressor setup, (450 psi), That shoots masonry coil nails. coil nailer is about the size of a finish nailer with a drum.
Duckweather is offline   Reply With Quote
Old 07-25-2012, 12:55 AM   #6
Rewards Points: 2,210
There are even hand nails you can get for concrete.
Tapcons (concrete screws) work well
mae-ling is offline   Reply With Quote
The Following User Says Thank You to mae-ling For This Useful Post:
oh'mike (07-25-2012)
Old 07-25-2012, 08:23 AM   #7
Rewards Points: 89
can i use the regular drill and drill it straight down or i need to pre-drill a hole first?
Old 07-25-2012, 10:52 AM   #8
Tap cons must be pre drilled into concrete. The kit comes with the correct size bit for the screws.
The powder actuated guns are hella loud in a basement. Wear hearing protection!
Evstarr is offline   Reply With Quote
Old 07-25-2012, 10:57 AM   #9
DIY staff
Rewards Points: 7,174
Those old nails were,most likely, hardened concrete nails--hand driven with a 3 pound hammer.
Old 07-25-2012, 11:07 AM   #10
Rewards Points: 89
thanks for the heads up!
Old 07-26-2012, 10:56 AM   #11
You need a 'Hammer Drill' for drilling into concrete a regular drill will not work.
These can be rented.
Tub Drain Removal Tool rjordan392 Plumbing 6 07-08-2008 12:39 PM
Tool question jerryh3 Electrical 2 05-10-2008 09:17 PM
total air tool beginner question (real e-z) amakarevic Building & Construction 4 12-30-2007 09:56 PM
Powder Room Framing Question Not Sure Building & Construction 9 08-11-2006 07:13 AM
water hammer question seanstoner Plumbing 7 04-10-2006 05:28 PM
