Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 10-01-2012, 05:57 PM   #1
Boris052's Avatar
Porch posts
Hello, I want to update my 4x4 front porch posts. I have researched a fypon retrofit system that does not require removing the current posts however my header is only 4 in wide and I do not know how to blend the tops in and have it look good with the new surround sticking out beyond the header? I was wondering if anyone had already encountered this and how/if you solved my dilemma? I plan on going to a 5x5 post look after the change.
Thanks in advance,
Boris052 is offline   Reply With Quote
Old 10-01-2012, 06:12 PM   #2
Boris052's Avatar
Porch posts
Here are some pics of the posts, did not have them for the original post.
Porch posts-image-1889882229.jpg   Porch posts-image-3105489796.jpg   Porch posts-image-538727604.jpg   Porch posts-image-2510414579.jpg
Old 10-01-2012, 06:13 PM   #3
Porch posts
Look at just about any older home with porch post, they all will stick out past the header.
Old 10-01-2012, 07:26 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Porch posts
if you make the posts bigger youll have to build out the beam to keep the proportions working.. having a reveal on the beam from the post is fine.. but a reveal to the post from the beam very wrong...
woodworkbykirk is offline   Reply With Quote
Old 10-01-2012, 08:25 PM   #5
Boris052's Avatar
Porch posts
Is that structurally or visually speaking?
Old 10-01-2012, 08:33 PM   #6
Porch posts
That a look at some of these pictures to see ways to trim it out if that what you feel you need to do.
http://www.bing.com/images/search?q=...ages&FORM=IGRE
Old 10-01-2012, 08:42 PM   #7
Porch posts
visual. structurally its fine.. looking up at a reveal is fine.. but if the beam is narrower than the posts it will look terrible
any time i frame a porch roof, the beam is typically 3 ply 2x8 or 2x10 which is 4.5" thick... the posts are 6x6 so they end up being 1 " wider.. so we add 1/2" ply to the side of the beam that is flush with the post and run 2x2's or an additional ply to the inside face to keep the 1/2" reveal. all our porch beams get clad in aluminum or azek. if the beam gets an azec treatment so do the posts
Old 10-01-2012, 09:17 PM   #8
AHH, SPANS!!!
Porch posts
I've installed monster posts and post bases that stuck out past the beam. some 2' post bases more than 8 inches stuck out in the air, it was what the homeowner wanted so... as long as it is sealed from the weather it's good though some birds seem to find them really easily. A single post with no detail looks real bad if sticking past the beam but add some detail to the part that sticks out and it does not look to bad.
hand drive is offline   Reply With Quote
Old 10-01-2012, 10:17 PM   #9
Boris052's Avatar
Porch posts
Thanks for all the info, some good stuff. My main hang up to widening the header is pulling the soffit and gutter down to do so. Maybe I will experiment with some ideas and see what I can come up with. Try tapering some sort of composite.
HOw to support 8X8 porch posts sp the bottoms can be replaced Earlofcarleton Carpentry 12 09-25-2009 10:31 PM
Stabilizing porch posts efingal Carpentry 4 07-21-2009 01:12 AM
Steel Posts for Screen Porch dobbsj Building & Construction 2 07-15-2009 06:47 PM
Advice for replacing porch posts pkovo Building & Construction 3 04-07-2009 08:59 PM
help settling porch posts - a dilemma. wombosi Carpentry 9 10-10-2008 01:01 AM
