Porch Insulation - Remodeling - DIY Chatroom Home Improvement Forum
Old 12-21-2009, 09:54 AM   #1
Porch Insulation
I have a screened porch that I would like to enclose and turn into living space. It is supported by concrete piers and 4x6 posts. It is on a slope so the low end is about 2 ft. off the ground and the high end is about 6 ft. off the ground. The floor joists are 2x6's. The underneath is easily accessible. There is no vapor barrier under the floor. What would be the best way to insulate under the floor of this porch? I'm located in western NC at an elevation of about 4,100 feet.
Any suggestions would be appreciated. Thank you.
PiedmontNC is offline   Reply With Quote
Old 12-21-2009, 11:32 AM   #2
The first step is probably to look up the joist size in a span table. 2x6 joists can't span very far for an interior floor.
If the 2x6's are sufficient, then I'd put rigid foam and fiberglass in the bays. Or maybe fiberglass and rigid foam continuous attached to the bottoms.
pyper is offline   Reply With Quote
Old 12-21-2009, 02:15 PM   #3
Registered User
Rewards Points: 5,492
I would contact your City or County Building Department first. They have safety codes for converting structures to living spaces. You need heat and ventilation, a proper foundation, electrical requirements, etc. to be safe.
Be safe, Gary
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
crawlspace insulation under porch shtoink Building & Construction 8 11-12-2009 07:50 AM
New Concrete Porch (Standing Water) ronbar Building & Construction 7 09-27-2008 06:54 AM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 08:33 PM
