Porch Flooring Over Concrete - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-30-2011, 03:06 PM   #1
Porch flooring over concrete
I have a concrete front porch but I was wanting to cover it with a wood looking type covering. The concrete has some cracks and I would like to cover these. I do not want to use pavers but would like to use something that gives a wooden plank like apperance.
rstepp is offline   Reply With Quote
Old 11-30-2011, 03:28 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Something that looks like wood and gives a wood-like appearance huh? H-m-m-m-m. One would have to think about that for a while.
Oh hey! Will it be getting wet at any time? Is the porch enclosed?
Old 11-30-2011, 03:42 PM   #3
nope, this porch is more like a deck
Old 11-30-2011, 03:43 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
So it IS exposed to the elements?
Where are you, what region of what country?
Old 11-30-2011, 06:40 PM   #5
Rewards Points: 5,336
So it's like a deck and you want a wood like appearance.
Sorry, I got nothing.
Ron
B. Franklin 1759
Old 11-30-2011, 06:58 PM   #6
kwikfishron's Avatar
Rewards Points: 1,006
It is usually possible cover a concrete porch with wood or “wood looking” decking.
You need to attach treated wood sleepers to the concrete so there’s something to attach the decking to.
You need at least 2” between the concrete and the threshold of the door to make this work.
kwikfishron is online now   Reply With Quote
Old 11-30-2011, 09:15 PM   #7
I've thought of doing something similar, but I'm concerned about water pooling under the wood. My patio is not sloped and concrete does not provide good drainage.
Jeoroc24 is offline   Reply With Quote
Old 12-01-2011, 03:41 PM   #8
Rewards Points: 150
Your wood deck will let water through to the concrete. If the concrete has no slope so it doesn't drain, then trapping water under the wood deck is going to stink, attract mosquitoes and rot the wood amongst other nasties I haven't tought of. If you cannot apply a sloping screed to the concrete (slope 1:100), your between a rock and a hard place. Just fill the cracks and use a good quality paving paint. Otherwise, screed to fall, and lay external tiles or paving stones, forget wood altogether.
Cheers, from Oz
JoJo-Arch is offline   Reply With Quote
Old 12-01-2011, 03:48 PM   #9
Rewards Points: 14,312
And no, composit decking will not work either, it needs at least 12" under it for air flow or it's going to mold up.
Attaching wood decking as stated will not work for other reasons, it will never fully dry out, as it shrinks when it does start to dry I've seen it snap off or pull out ceramic coated decking screws.
Old 12-02-2011, 01:27 PM   #10
I covered my cracked concrete porch deck with rubber tiles made from recycled car tires. They are about 16" square, come with a house brick pattern on them. They are dense enough that can lay in place without adhesive.
Old 12-02-2011, 02:32 PM   #11
where did you purchase and do they have various colors?This sounds like a good option. Thanks
Old 12-02-2011, 07:41 PM   #12
I bought the tiles from a RONA HOME CENTER here in Canada. They were made in Montreal, however the brand name is gone from me. ( I have a good memory, its just short)
I may have the sales receipt yet. I'll have a look and see if I can find it!
The Following User Says Thank You to Wildie For This Useful Post:
rstepp (12-05-2011)
Old 12-02-2011, 08:39 PM   #13
I have a link http://www.diamond-safety.com/Deck,%...0Products.html that show a type of rubber tile. Mine is a different manufaturer. I have yet to find the name.
Old 03-26-2012, 06:33 PM   #14
Hi all
I was looking for something like the diamond-safety for a concrete pool deck, any one can give us a review/comparison about it. The finish on our concrete deck is AAA on drainage, but not a good kids friendly surface.
Thank you.
Mary.
magallanes is offline   Reply With Quote
Old 08-16-2014, 10:11 AM   #15
Originally Posted by magallanes View Post
Hi all
Thank you.
Mary.
Hi Mary,
My name is Bob. I am president of Diamond Safety Concepts. I would be happy to answer any of your questions about our rubber tiles and pavers although this forum is probably not the proper venue.
A quick visit to our web site, (see the link in a previous post), will provide you with all the appropriate contact information. Please give me a call or send an email.
The short answer is that our rubber decking tiles are great for most outdoor resurfacing applications. The rubber is porous so water will drain through the tiles to the subsurface below. This material can be installed directly over fragile waterproof rubber membranes. These products are made from the same type of recycled rubber that is commonly used in playgrounds so they provide excellent cushioning and slip resistance.
The only issue you might run into is how to deal with the transition from the rubber tiles to the pool coping since our tiles range in thickness from 1/2" to as much as 4".
dsafety is offline   Reply With Quote
Laminate Flooring on Two Different Concrete Heights mrken Flooring 4 12-14-2010 01:56 PM
stinky concrete and laminate flooring princessupdo Flooring 3 08-10-2010 11:19 PM
covered concrete porch..what kind of floor? captjackny Flooring 4 02-26-2010 10:47 AM
adding a deck to existing concrete porch idiotbox37 Carpentry 6 12-02-2009 07:48 PM
laminate wood flooring over concrete janet.giron Flooring 3 07-28-2009 04:47 PM
